07-26-2014, 08:51 PM | #1 |
cam for lq4
hey guys i need yalls opinion on a cam for my lq4, its going in a 84 c10. i have the engine tore down replacing bearings and gaskets and was thinking of porting the heads now that its open and as well put in a cam to beef it up a little bit.
07-26-2014, 11:48 PM | #2 |
Re: cam for lq4
You probably want to include a ton more info or call a LSx cam company (Texas Speed, Tick, Little Jon Motorsports)
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
07-27-2014, 05:17 AM | #3 |
Re: cam for lq4
probably the most important thing is, what's your plan for the truck? daily driver weekend warrior?
07-27-2014, 09:00 AM | #4 |
Location: Sunny, Florida, some might call it South Alabama
Re: cam for lq4
I have a similar set up to yours....see my sig...I love it
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
07-27-2014, 01:07 PM | #5 |
Re: cam for lq4
its gonna be a daily driver, i was thinking of a 212/218, what yall think
07-27-2014, 02:40 PM | #6 |
Re: cam for lq4
I do agree with the above post...call summit or texas speed or Brian Tooley, and let them know about your set up and what your goals are and they will spec you the best cam for your particular application.
07-27-2014, 08:58 PM | #7 |
Re: cam for lq4
I have a 224/230 114 cam in my LQ4, it has some sound to it but sometimes I want it to talk more. the 212 cam will hardly be heard but will give you increased torque.
Just depends on what your goals are.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
07-27-2014, 09:17 PM | #8 |
Re: cam for lq4
thats what im looking for, torque and i have 3200 stall to go with it
07-27-2014, 09:30 PM | #9 |
Re: cam for lq4
228 228 588 588 112+4 will work perfect on an lq4. Milling the heads .030 will definitely improve all around hp/tq
07-28-2014, 07:46 AM | #10 |
Re: cam for lq4
Hop on YouTube and search for 212 or 228 cam videos. You can definitely hear the difference and go from there. It depends on your truck purpose and how choppy you want your idle.
Go to the link in my signature for some of my projects that have cams in them. They go from mild to pretty radical. Especially the sound of the new cam in the dark blue GTO.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
07-28-2014, 07:43 PM | #11 |
Re: cam for lq4
3200 stall with a small cam is not really a good match. probably a 228ish cam with .580 lift on a 113 or 114 would be what u are looking for. not too big but big enough to be happy with.
07-31-2014, 11:12 AM | #12 |
Re: cam for lq4
In my opinion, you are going to want an earlier intake valve closing point to get dynamic compression up as the lq4 is a bit lower static wise to start with. An earlier ivc is also going to keep the rpm band lower which is better suited for the truck intake.
I can give you a real suggestion later. It would be based off comp cams lobes. Essentially you would call them, give them the intake/exhaust lobe number as well as intake center and exhaust center.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
