Old 07-29-2014, 12:16 PM   #1
Mrhorsepower92
Transmission hump
I got a question about transmission humps. what type of trucks used the tall humps was it just manual transmission and 4x4s. where they ever used on a 2wd big block auto.
Mrhorsepower92 is offline   Reply With Quote
Old 07-29-2014, 01:16 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Transmission hump
I believe the bolt-in high humps were 4x4 and big block only.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 07-29-2014, 11:23 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
4x4 or 4 speed or big block with auto trans trucks got them.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 07-30-2014, 12:19 AM   #4
Mrhorsepower92
Thanks for the help my 72 stepside is missing the hump and I was curious if it was correct for a big block auto
Old 07-30-2014, 06:57 AM   #5
71sixgun
Only the 3 speeds had the small hump.
71sixgun is offline   Reply With Quote
Old 07-30-2014, 07:37 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
And TH-350 and Powerglide automatic trucks.
Keith
Convert to disc brakes.
Old 07-30-2014, 10:55 AM   #7
hugger6933
If your truck is missing the hump and the high hump is the only one that bolts in wouldn't that narrow the field? My 68 GMC is a high hump it was 396 T400 it also is/was a 3/4 ton. I prefer the high hump as for the look inside as compared to the low one that is one reason when my 70 3oot is changed to the T-5 I am doing it back with a high hump as well. Jim
hugger6933 is offline   Reply With Quote
Old 07-30-2014, 11:10 AM   #8
Mrhorsepower92
Thanks I didn't realize the high hump was the only one that bolts in
Old 07-30-2014, 11:16 AM   #9
FirstOwner69
FirstOwner69's Avatar
My original 69 3/4 ton 2WD with 350 and TH400 has a low hump also.
FirstOwner69 is offline   Reply With Quote
Old 07-31-2014, 08:01 AM   #10
71sixgun
I didn't realize that the th350, th400 and the powerglide had low tranny humps well.
Old 07-31-2014, 02:14 PM   #11
motorcritter
motorcritter's Avatar
Scored a '72 Custom 20 with a rotted cab (I think I can lift the roof section off by hand!), but a nice high hump section. This will go into the '70 C10 T5/TPI set-up rather nicely.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
