08-02-2014, 12:34 PM | #1 |
62 c10 with 78 front end control arm question
Put a set of 2-1/2" drop spindles on my '62 and now the rims contact the lower control arm. How much can I safely trim? looks like it only needs a dog-hair off.
Front end is out of a 78 c10...wheels are 15x7 rallies... |
08-02-2014, 05:04 PM | #2 |
Re: 62 c10 with 78 front end control arm question
If you trim you will want to box the arm or a weakness in the arm will alow the balljoint area to bend.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-02-2014, 08:52 PM | #3 |
what about moving the rim out with a slip on wheel spacer? if its only just touching you will only need a thin one. saves cutting up your lower arms to.
08-02-2014, 09:36 PM | #4 | |
But Found Her 25yrs Later!
That's a good idea.
