Old 08-01-2014, 06:35 PM   #1176
Vic1947
Vic1947's Avatar
Re: Crusty Rusty Leaky Squeaky 67 Step
Originally Posted by knomadd View Post
You could go with Porterbuilt arms! I'm running their lowers with a 1" forward offset. The set moves the wheels forward in the wheel opening by an inch if you do both upper and lower, but about 1/2"-3/4" with just the lowers. Stock arms would be cheaper though.
I'd send you mine, but one is beat up. If you feel like straightening one of the bushing mounts, and replacing the ball joints/bushings, I'll let you have them for the cost of shipping. Let me know if you're interested and I'll take some pics.
Thanks for the offer, Duane. There's a specialty yard over in Lenexa that keeps tons of the stuff. Just need to get off my butt and go over there. As heavy as the arms are, they can be expensive to ship. Plus, it's useful to wait just a bit sometimes. Never know when someone local will pop up and holler, "I got some that were just rebuilt!" The sad part is I let a completely rebuilt, powder coated set of uppers and lowers go for cheap at a swap meet about a year ago. Being a neat freak, anti-hoarder has it's drawbacks.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 08-03-2014, 08:18 AM   #1177
snipescastle2
snipescastle2's Avatar
Talking Re: Crusty Rusty Leaky Squeaky 67 Step
Vic,
I have a set of lower control arms for a drum brake front end, sont know if these will help, but I'm willing to give them to you if you want them......
I only have the lowers, I can shot blast these and powder coat them black for you as well.......
let me know.
Ben
snipescastle2 is offline   Reply With Quote
Old 08-03-2014, 08:36 AM   #1178
Vic1947
Vic1947's Avatar
Originally Posted by snipescastle2 View Post
Vic,
let me know.
Ben
Thanks, Ben, the lower arms are all I need. I started modifying the DJM arms that came off of it yesterday to see if I can make them work. I think it may be possible. However, I'll PM you if these don't work out and arrange to get yours. Should know something today. Thanks again!
Victor
Old 08-03-2014, 09:17 AM   #1179
snipescastle2
No Worries Vic!
have a great Day!
Ben
Old 08-03-2014, 09:40 AM   #1180
Xeen
Xeen's Avatar
Vic you could just make a new set and sell those.
No but seriously you will figure it out, I wouldn't stress over it too much.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-03-2014, 12:16 PM   #1181
Elliot949
Elliot949's Avatar
I finally got to meet Vic and his Bride Kathy Yesterday... what a wonderful couple... They made my wife and I feel like old friends... Now for the truck.. Guys if you haven't seen Vic's work in person you truly don't know how AWESOME this truck is... Picture really do not do this truck Justice...
His other project is just as awesome...
Dan
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 08-03-2014, 03:54 PM   #1182
Vic1947
Vic1947's Avatar
Dan
Hey Dan, thanks for the comps! You all can drop by anytime if you're gonna say nice stuff.
We really enjoyed your visit as well. Hope you got all your errand running done, sounded like you had a full schedule. Looking forward to seeing the "Class Act" come together.
Victor
Old 08-03-2014, 05:59 PM   #1183
Vic1947
Vic1947's Avatar
I think I've come up with a solution to the control arm situation. It finally occurred to me that the key to making this work had to start with the position of the airbag in the lower control arm. Get it where you want it, then reinstall the control arm and mark where the top lands on the upper plate. Remove the plate and relocate the hole pattern as needed. There's a ton of room where the coil spring goes up thru the crossmember, so I can't see there being any interference with the bolt heads or the 90* air fitting.
So I removed the bottom spring retainer cup, cut off the ledge where the sway bar bolted up and removed one of the reinforcement bars that was in the way. I'll relocate it so I have plenty of clearance around the entire bag. I'll also build a 1.25" spacer to weld on the bottom plate, then mill a window below it for access to the mounting bolts.
After cleaning up the surrounding area, I mocked up the bag where it would sit if I were to mount it in the stock location. You can see from the photo it's hard up against the tubing. So I'll move it over and toward the ball joint slightly. That will give me plenty of clearance all around. When Dan was here yesterday he told me about a guy who had a bag blow out going down the road at highway speed. Truck immediately went down all the way and suffered major damage before it stopped. I don't need anything like that to happen, so I'm going to do whatever's necessary to insure none of the bags is even close to rubbing on anything.
Victor
Old 08-03-2014, 06:02 PM   #1184
Elliot949
Elliot949's Avatar
Man that sounds like a great solution...
Old 08-03-2014, 09:55 PM   #1185
Low Elco
Seems like that'll work! Thanks again, the pan fit awesome!
Low Elco is offline   Reply With Quote
Old 08-03-2014, 09:56 PM   #1186
Xeen
Xeen's Avatar
Attaboy Vic I knew you would getrdone.
Old 08-04-2014, 09:57 AM   #1187
snipescastle2
Vic,
Looks Great! Glad you sorted it out!
Ben
Old 08-04-2014, 08:42 PM   #1188
Vic1947
Vic1947's Avatar
Woke up this morning with big plans for the day. Get the lower control arms ready for the mounting brackets, fabricate the brackets out of some 14ga SS tube I've had for-ever, revise the rear mounts to eliminate the angle iron and set them up like the ones you can buy. Just a little laundry list that seemed very do-able while drinking a cup of coffee and reading the paper. As the day progressed, however, reality set in and what I actually got done pales in comparison to the wish list. I did get the SS tube cut and turned to length as well as slots milled in the ones for the rear to allow the air line connections. I also welded a reinforcing tube back in the first control arm and began cutting on the second one. The rest of the day was spent yakking on the phone and staring into space (planning). Ahhh, there's always tomorrow...
Victor
Old 08-04-2014, 09:29 PM   #1189
Low Elco
Ain't retirement great?
Old 08-04-2014, 09:30 PM   #1190
jeh
jeh's Avatar
Nice work again Vic
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 08-07-2014, 06:23 PM   #1191
Vic1947
Vic1947's Avatar
I think I'm putting in more hours now than I ever did while working.
Originally Posted by jeh View Post
Nice work again Vic
Thanks Jay.
I've spent the last coupla three days doing mid-course corrections. Wasn't happy with some of my previous efforts so I started over. The reinforcing tube I removed and reconfigured turned out to be unnecessary. So I cut out the tube I scabbed on and replaced it with a chromoly tube in the original location. The spacers I built move the bags up enough away from those tubes that they won't rub. Had I left the spacers out, there would have been an interference issue, but that's not the case now.
Also the more I looked at the rear spacers, the less I liked the angle iron. Angle has it's uses, but this was a bit crude, so I cut them out and revised the spacer to be more like the ones I saw for sale on a couple of sites. The main difference was that I put a cap on the top of mine with a captive nut welded in instead of a stud coming up thru the middle. Put a couple of access holes in the cap so I can attach the fasteners to the top of the bag.
Victor
Old 08-07-2014, 06:34 PM   #1192
Vic1947
Vic1947's Avatar
I also got the upper plates trimmed, re-drilled and mounted to the front crossmember. I now need to put some access holes in the bottom plates of the lower control arms. I noticed something when marking the locations of the lower spacers. Both control arms are stamped with the end of the coil spring groove facing toward the oil pan. So on one side, there's a nice flat surface where the spacer seats. On the other side, however, part of the spacer perimeter will cross the groove. It will only be unsupported for a couple of inches, so it shouldn't matter.
Victor
Old 08-07-2014, 06:55 PM   #1193
Elliot949
Elliot949's Avatar
Nice work as always Vic...
Old 08-07-2014, 07:44 PM   #1194
sduckworth13
sduckworth13's Avatar
Nice work Vic, I always like to see your work. It always looks brand new when your done.
Scott
sduckworth13 is offline   Reply With Quote
Old 08-07-2014, 08:56 PM   #1195
swamp rat
swamp rat's Avatar
School is in session!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-08-2014, 08:44 AM   #1196
Low Elco
Looks good! Always enjoy seeing Innovation in Action!
Old 08-09-2014, 06:07 PM   #1197
Vic1947
Vic1947's Avatar
We had company from Houston, TX and Jeff City, MO at the house yesterday, so all I did was show off stuff. But today, I finished up a couple of things I've been doing in background, then got busy and put access holes in the lower control arms and tack welded the bottom spacer in. Attached the bag to the spacer and reinstalled the control arm. With the suspension set at the approximate ride height, the bag should extend to approximately 5.5" - 6" when inflated. The advertised range is 2.7" to 12" but the tech at Slam said they work best in the 5" to 8" range. It's really hard to know what I'll end up with, but I think I have enough adjustment to arrive at a decent height and stance.
I was pleased with the clearance between the bag and the lower control arms. The bag sits forward of where it probably would have if I'd used the stock or purpose built arms from Porterbuilt. I don't think it will make a big difference in the leverage the bag has on the crossmember, however, I'm open to suggestions or honest critique. This is my first airbag rodeo, so I got nuthin' to go on.
Victor
Old 08-09-2014, 06:33 PM   #1198
Xeen
Xeen's Avatar
Looks good to me Vic, I'm no rocket scientist but I wouldn't think it would cause a problem.
The bag angle is static so all that matters is the lower arm.
The upper mount really has no bearing as long as the bag is perfectly vertical and from what I can see it is.
At least that's what makes sense to me.
P.S. Is there any interference from the tie rods?
Old 08-11-2014, 08:12 AM   #1199
Low Elco
Looks fine, as long as the bag's supported by good meat on both ends and nothing rubs, especially at full compression. Seems to be all good sir, roll on!
Old 08-11-2014, 11:21 AM   #1200
jlsanborn
jlsanborn's Avatar
Nice and tidy and well thought out!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
