Fabricate till you "puke"
1st ride, ls
The 1 st ride was really sweet...don't beat on the new clutch, go easy....After the clutch hooked, drop the hammer, about 1/2 down...that fing stock 5.3, took that old longhorn side ways! YEE HAW! The 1st ride, is allways the sweetest
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: 1st ride, ls
Sounds great man, can't wait till i get my 5.3 in, trying to figure out how to mate up my nv3500 to it for now. What engine did you have in it previously?
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
Re: 1st ride, ls
The former engine , was a mild 383 build...but I got tired of the fuel cost? The old 383, is in my bro's S-10, running 12.7's on the track
meowMEOWmeowMEOW
Re: 1st ride, ls
Don't underestimate yourself on the power. I forget your exact setup, but even with a simple tune you should be at the 320-330's, which is what I find MANY older 355-383 level builds considered "good" power.
These engines also FEEL slower, because of the throttle response. They are much smoother, and you never get the "whoooooaaaaaaaa" when the power enrichment-thingy in carbs goes open. If you wanna feel even slower, put big tires on the back (you'll run faster, but feel slower).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: 1st ride, ls
A guy told me his truck with a 383 could give me some competition.But so far with all this new found power and torque I feel like I could outrun anything lol. man I just find any excuse to drive my truck now.
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
Re: 1st ride, ls
She is a rock /stock 5.3 long block (fresh grind + LS-6 springs). I am running carbureted(600 edelbrock, on an rpm intake....figure , that it is what it is (about 300hp)? Hooker streetrod shorties/mandrel bent downs....2 1/2" pipe, all the way out/H pipe/50's flows. The 6 spd Richmond box (3.28 1st gear), is backed with 3.40 gears in the rear. Longhorn
Re: 1st ride, ls
Sounds nice! Google LS327 on youtube the HotRod guys dyno a LS327 with a 650 carb and manifold. Made around 347 hp or something like that.
![]() Join Date: Aug 2004
Re: 1st ride, ls
This is not true! He hasnt provided any pictures so it can not be substantiated!
just saying!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: 1st ride, ls
Page 10...69 longhorn ls swap (pics). You should find the thread at the top of the page
Re: 1st ride, ls
Well,ok....what do you really want? Do you want to see the truck? 4 " chopped top, 1 1/2 " channel, steel tilt clip....ect,ect? I am a little puter illiterate....but one of my sons, can get what you want to see? The kid , can probably get you an idle clip, on the old truck....it wont be that impressive, the old boich pulls 22 inches of vacumn @ idle(700 rpms)? Longhorn
