08-03-2014, 10:39 PM | #976 | |
Re: What did you do to your truck today? Chapter II
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
08-04-2014, 12:41 AM | #977 |
I pulled 8 heads at the junkyard and only one wasn't cracked. I bought it for $45, but had to completely rebuild it. I bought a new one also and had the guides machined down and screw-in studs put in. I've probably got $650-700 in the pair.
08-04-2014, 01:31 PM | #978 |
08-04-2014, 07:59 PM | #979 |
Trying to get this cleaned up and looking nice.
Working on the A/C and getting my seat changed to black. |
08-04-2014, 08:38 PM | #980 |
Changed some parts on the top of the motor to shiny it up a little!
08-06-2014, 02:04 PM | #981 |
Well, so far today, I've installed a new spacer between the balancer and crank pulleys, mounted the right side motor mount, installed a new stainless heater hose fitting into the water pump, painted the short head bolts, cleaned up my carb and installed it with a new heat insulator gasket.
Later, I'll probably clean up the ram horns and brush Por-15 gray manifold coating on them. |
08-06-2014, 02:37 PM | #982 |
well the west Texas heat ,sun, and not much rain has taken a toll on old dollor's wood bed ....time to do something different . started sanding last night and will try and finish the prep work today , decided to go with a spray or roll in bed liner and see if that will last longer, living outside is hard on pickups. pic's will come later...Don
08-06-2014, 03:53 PM | #983 |
I charged up the Vintage Air in the 67 today!
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
08-06-2014, 07:56 PM | #984 |
I figured it was time to repair the holes in the tailgate left by the PO. I heard that he backed up too far while attempting to hook to up his 5th wheel trailer & punched two identical holes in the tailgate. Believe it or not this was my first time to ever do any sheet metal repair in my lifetime. Not too bad for a rookie huh?
"Now all I need is a shop to go with my shop vac!" |
08-06-2014, 09:45 PM | #985 | |
08-06-2014, 10:05 PM | #986 | |
And why expensive ? Just some simple tongue and groove |
08-06-2014, 10:25 PM | #987 | |
RAT1968 '68 Cab/'71 Parts
Not like my $50 surplus wood floor job.....Which actually seems to be holding its own...for now.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
08-06-2014, 10:26 PM | #988 |
08-06-2014, 10:31 PM | #989 |
its not to bad if you build your own bed kit, that's what I did ,but the clear coat went first and the stain was looking real bad , ole dollor is not a show truck so its time to put roll in bed liner and hope the west Texas sun leaves it alone....hey your tail gate is looking good. looks like a pro. repair ..
08-07-2014, 01:09 AM | #990 |
Yea, it's labor intensive for me. I had a spinal cord injury 30 yrs ago due to a rodeo accident, so I don't get around like I use to, but I still get stuff done and can dang sure work on classic cars & trucks - it's my passion. For my situation I am going to remove the bed to make it easier to remove all the 72 bolts and not have to deal with the driveshaft & dual exhaust, etc.. being in the way. It can be expensive if I was going to buy a bed kit, I've seen some costing as much as $500 or more. But luckily my neighbor (that has a wood shop) has generously offered to cut & tongue/grove & stain the boards for me, so that's the route I am taking for my wood bed. And just buy the strips & bolts from classicparts.com.
08-07-2014, 01:11 AM | #991 | |
08-07-2014, 01:20 AM | #992 |
Wow! That looks nice! Very different & I like that, something you don't see everyday. I'm not sure a wood bed like that would survive out in the extreme weather conditions here. Since mine is parked out the elements 24/7, its a go truck - not a show truck.
08-07-2014, 01:31 AM | #993 |
Put my cab paint dividers on
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!! |
08-07-2014, 01:43 AM | #994 | |
It has been around 105 or so for a couple of weeks up here by Yosemite. It only gets cold....like around 20 or so for any kind of "stretch" a couple of times a winter. We get different amounts of snow. But sometimes, we get snow in April...Here's some light stuff: RAT has to live outside 24/7, too. And, she gets used like a truck. Maybe not as heavily as some....Sits at a few shows as a "driver" against some real pretty $$$ up show-rides. I'm not there to win, though. Just to jawbone. But, I have to admit that when I put something in the bed, either the mats or a tarp go down. I have to figure out some sliders for this floor. So far, that hasn't kept me from using her like a truck. And, oh, I have to admit that RAT has a cover on her. And during the rain/snow months has a water-tight snap on rails tonneau.
08-07-2014, 01:54 AM | #995 | |
08-07-2014, 02:22 AM | #996 | |
Two sheet metal screws thru the two last pieces of wood at the far right, and five screws thru each of the two aluminum strips at the front and rear of the bed. It's just t and g (real wood) flooring we had left over from the house (I actually made sure they left an extra box). The whole floor comes out in less than five minutes. I numbered them and put an arrow to the front on each piece. If I need to (only one time so far), I can put it back in under fifteen minutes. It's not for everyone. But I had the stuff. And, for about fifty bucks.......
08-07-2014, 12:34 PM | #997 |
pretty much sums it up
08-07-2014, 01:49 PM | #998 |
Oh god that funny^^^^^^^^^^^^^
Anyway, I painted my cab white and pulled the front bumper to do the same. |
08-08-2014, 04:39 PM | #999 |
Finally got my exhaust manifolds stripped/cleaned and painted with Por-15 factory gray manifold paint.
08-08-2014, 05:06 PM | #1000 |
So very well said!
More clean, prep, paint/coat..repeat. But it's looking better. Got the front-end minus the sway bar and gear box done. I need to take the sway bar to the blaster. Whats the best method of cleaning the gear box before I do a rebuild on it? Here are some more pictures. I really am liking how the red and black is turning out. My HF powder coat system is working out alright. Please excuse my fat finger in that last shot.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress) 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
