Old 08-03-2014, 10:46 PM   #1
Mv7fd
Radio antenna
I have the antenna that's in the windshield has anyone ever gotten a regular fender mount antenna and used it instead of the window
Mv7fd is offline   Reply With Quote
Old 08-03-2014, 10:56 PM   #2
MountainGoat1966
Re: Radio antenna
I did and now I'm sorry.
I have a hole in my fender I need to weld up and do body/paint work on it.
I will spend the money for a new windshield if I ever get another stereo for the truck.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 08-04-2014, 07:50 AM   #3
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: Radio antenna
Yea I would go the new windshield route, I know around here in Houston you can get a brand new one for right around $100, well worth the money in my opinion.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 08-04-2014, 05:25 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Radio antenna
I put the antenna in my fender and with the reception that is available in the middle of Kansas, I am not sorry that I did it. However, I am running a Sirius XM setup, now.
Frank
Old 08-05-2014, 12:20 PM   #5
IdahoStepside
Re: Radio antenna
I have a related question. I have preexisting fender antenna that was missing. I have the replacement, but how does the cable get routed into the cab? Cable is too short to run to center of firewall where existing openings are.
IdahoStepside is offline   Reply With Quote
Old 08-05-2014, 01:09 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Radio antenna
My 79 has a drivers fender add on,it's just an 3 foot extention (same in/out).
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-05-2014, 01:30 PM   #7
piecesparts
Re: Radio antenna
The hole for my antenna, is on the right hand side of the cab just behind the door opening. The antenna cable feeds down from the fender and along the cab to the point where we made the hole. Once inside you can purchase a short extension to reach your radio, if needed. You do not want to run the cable close to your ignition components, if possible. That would possibly give you interference in your radio reception.
Frank
Old 08-05-2014, 04:47 PM   #8
IdahoStepside
Re: Radio antenna
Where is the "same in/out"? Is there a hole in firewall behind fender?
Old 08-05-2014, 05:15 PM   #9
piecesparts
Re: Radio antenna
Computer controlled trucks have a rubber grommet just behind the passenger valve cover on them.
Frank
Old 08-05-2014, 08:44 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Radio antenna
i meant the same type of plug in/out ,some make them into adapter wires (too)
John
