Old 08-05-2014, 06:15 PM   #21
SCOTI
SCOTI's Avatar
Re: Dually Alcoa question
Originally Posted by kevinr1970 View Post
Is the black ring a Dodge thing? If not, what was/is its purpose?
It seems that I should be able to run the standard compression ring/lug-nuts with the hub cover mount underneath it. Like on the stock steel wheels?
Check w/rs72z.... But.... I recall the 'hub' caps installed from the outside & will not fit from behind.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
