08-04-2014, 02:12 PM | #1 |
little tricks
I learned a little trick today, purely by accident, I applied some filler to a vintage license plate, but hadn't added enough catalyst, so it didn't kick. I sprayed it down with carb cleaner and a wire brush to remove the filler, to discover you can remove alot more rust and what-not with a wire brush just by spraying a little carb cleaner on it! I scubbed the plate alot before adding the filler and was confident nothing else was coming off, but with the carb cleaner, ALOT came free!
anyone else have a little trick that works well for them? -Eric
'06 2500 HD 4x4. manual transfer case, crank windows. '88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project. My trucks don't leak oil, they mark their territory. |
08-04-2014, 03:59 PM | #2 |
Re: little tricks
Thanks for the tip
08-04-2014, 08:52 PM | #3 |
Recovering Truck Driver
Re: little tricks
WD-40 will work when tire lube won't work to get old hard tires to come up and seat the beads.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
08-05-2014, 09:28 AM | #4 |
Re: little tricks (Tribal Knowledge)
In my workplace we call these types of tips and tricks: "tribal knowledge", because they are rarely written down, this information usually gets passed from one person to another verbally, like lore in the olden days.
I hope this thread takes off and becomes a sticky, with all the experienced and helpful folks on this board, I am guessing the shear volume of tribal knowledge would be simply astounding as well as invaluable to us all of us, regardless of experience level. Please share what you know! (I know I didn't share anything...I'm thinking ) -Ed Last edited by EdSevered; 08-05-2014 at 09:36 AM. |
08-05-2014, 11:07 AM | #5 | |
Re: little tricks
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-05-2014, 09:24 PM | #6 |
Re: little tricks
A tip I saw on here to make bedside removal from the floor easier, was to tighten (and snap off) the little carriage bolts that hold the bedside on. They normally want to spin.
08-05-2014, 09:28 PM | #7 |
Re: little tricks
Who's driving on old hard tires? They're OK for parking on the lawn at Pebble Beach, but I wouldn't drive on tires that old....
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
