Old 01-13-2004, 06:58 PM   #1
Hugger
Hugger's Avatar
What the ....!!!!
I got new dual exhaust put on today...Looks great, Sounds great, but on the way home it's not running right???
Seems like timming, but I can't figure out why it started now. I havn't drove it for several months, but on the way to the shop I didn't notice it running bad.
On the way home it was backfiring, missing you name it.
I havn't had time to look at it close yet, hopefully It'll be something simple.
Any guesses??
By the way I got MagnaFlows with an H pipe, exiting back corners (Hidden Turndowns)...Looks great!
Thanks.
72 LWB - Hugger Orange
350/350 3.73
Next; 335hp GM Crate
Hugger is offline   Reply With Quote
Old 01-13-2004, 07:01 PM   #2
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
You now have different back pressure and you are going to have to retime your engine.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 01-13-2004, 07:03 PM   #3
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
What size exhaust did they put on it? That will definately have an effect on the engine's performance. And it might not run right.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 01-13-2004, 07:04 PM   #4
Hugger
Hugger's Avatar
That's what I was thinking but I didn't know it would make that much difference...
First thing I thought of was the cross over...
Thanks, for the quick reply.
350/350 3.73
Old 01-13-2004, 07:05 PM   #5
Hugger
Hugger's Avatar
2.25" pipe
350/350 3.73
Old 01-13-2004, 07:35 PM   #6
Hugger
Hugger's Avatar
I will get the timming light out tonight and see what I can see..
I tried to time it once before, and finally had to take it in to the shop...The guy told me it was 180 out????
I don't see how this is possible and have it still run at all, but what ever he did made it run better.
I guess I'll try again.
Thanks.
350/350 3.73
Old 01-13-2004, 08:11 PM   #7
cdowns
cdowns's Avatar
if it's been sitting for awhile now might be a good time to change air and gas filters and throw a couple cans of drygas in the tank
Old 01-13-2004, 09:28 PM   #8
jhow66
jhow66's Avatar
New pipes would not make it backfire or miss .Did they have your plug wires off for any reason? If so a couple could be crossed.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-13-2004, 09:31 PM   #9
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
I agree with the wires. New exhaust wont make that much difference in timming. The main thing i would worry about if you have headers too is the fuel mixture will need to be richened. Which is carb. An engine will not run 180 off either so i guess im confused.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 01-13-2004, 09:31 PM   #10
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
not only off make sure that they didnt make any of the ignition wires or any of the harness touch the manifolds or pipes that will short it out or cause a miss too
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-14-2004, 12:20 AM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'll asume the headers were new. If so, look for a primary tupe that still has paint on it...that will be the cylinder not fireing.
If they all have paint burned off, then I would go over the fireing order...the 5 & 7 get flip flopped quite easily, and it'll run about like you describe.
Old 01-14-2004, 12:25 AM   #12
djracer
djracer's Avatar
also make sure they didn't put the mufflers on backwards!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-14-2004, 12:39 AM   #13
Hugger
Hugger's Avatar
I checked the timming, and it was about 14 BDC, I adjusted it from 4 to 16 and all in between. I think it should be at about 8. It runs better at about 14, but the problem is there through out all adjustments.
I swaped the cap with my daily driver, no difference.
It has that da....da...da..da.da.dadada sound when you get on the throttle, missing!!!
Checked all wires, didn't see anything bad.
It has the original rams horn exhaust manifolds, so I can't tell which cylinder is the culprit witht the paint trick. I tried pulling a plug wire off here and there, but it doesn't seem to change it?
I put the timing light on all the wires, and all appear to be firing, but I don't think that is a good test.
Will try again tomorrow.
Thanks, for all the replies. It just realy pisses you off when you fianally spend the money for new exhaust and it won't run to hear and feel it....
Thanks.
350/350 3.73
Old 01-14-2004, 12:46 AM   #14
Hooter
My other Love
Hooter's Avatar
hmm does it have HEI? hows the distributor cap? firing order right?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-14-2004, 01:05 AM   #15
onelow69
onelow69's Avatar
I had a simlar problem after I had exhust done. This might sound weird, but the guy that welded my exhust used a mig welding machine. Well as most of you know welding with a mig uses high current between the neg or ground and the mig tip of the gun. Well come to find out what had happened is that the electic current from the welder shorted out the HEI unit, and that what was causing the mis-fire. So word of caution, always disconect the ground from the battery or disconect the dist from all of your electric system before you have any welding done.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect.
onelow69 is offline   Reply With Quote
Old 01-14-2004, 01:08 AM   #16
Longhorn Man
You can spray water onto the manifolds after a few min of running to get the same effect as the paint deal.
Old 01-14-2004, 01:20 AM   #17
Hugger
Hugger's Avatar
That is wild Onelow69, but I have points....thinking about going HEI maybe will befire I get this problem resolved.
I will try the water deal tomorrow.
Thanks Longhorn Man
350/350 3.73
Old 01-14-2004, 05:17 AM   #18
doughby82
doughby82's Avatar
holy crap your lucky thats all that shorted out.yeah i never weld when the battery is connected
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
