Old 08-06-2014, 09:48 PM   #11
clinebarger
Re: 700R4 build thread.
Parts ordering.
I highly recommend using 4L60E frictions in ALL '87-'93 700R4's, Along with late "E" molded pistons in the Input Drum.
This is an "E" kit with Borg Warner frictions (Hi-Energy 3-4 clutches & 2/4 Band), Raybestos steels, Teflon pump bushing, Case bushing & molded pistons Amazon.com: 4L60E 4L65E 4L60-E Master Overhaul... Amazon.com: 4L60E 4L65E 4L60-E Master Overhaul...The Filter & Valve body gaskets WILL NOT work on 700R4's, But at $172 the filter & seal kit are free. And its good for a first timer to have extra seals
700R4 seal kit, TransTec has the Lip Wizard Lip seal tool included.
700R4 Filter, SPX-Filtran
4L60E Overrun return spring assembly, GM part# 4206085, Needed for molded pistons.
Borg Warner 29 element Forward Sprag
Borg Warner Low/Reverse Sprag
Sonnax pinless accumulator pistons (2) http://www.sonnax.com/parts/2520
Sonnax purple accumulator springs (2) http://www.sonnax.com/parts/1660
TransGo SK 700-JR, Their TV kit is top notch. Good accumulator bushing spring selection as well. The rest of the kit does not work well in all transmissions!
TransGo Pump Rings
New pump Vanes
TransGo 700-p separator plate
Sonnax wide sun gear bushing
Sonnax wide Stator bushings
GM 3-4 apply plate, Part# given earlier
Torrington/Koyo bearing kit
clinebarger is offline   Reply With Quote
