Old 01-12-2004, 10:47 PM   #1
Riveted1
Tasty Cakes!
Riveted1's Avatar
leaning truck
Hey guys,
I posted earlier about helping my friend remove some leafs from his truck. Well, with your help, we accomplished that feat. But now the front driver's side is one inch higher than the other corners. Could it be that all of the other springs have more give? Or is there something else amiss? I don't know the history of this truck (if it was wrecked or not). Should I just heat up that coil to bring it down? Help!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 01-12-2004, 11:17 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
never heat coils it can be very dangerous. if you have spring problems switch out the whole set. mine leans too and thats what im doin to mine especially if youre a big gguy like me the springs ont he left seem to wear faster than theright one especially if the gas tank is on that side.. more weight on a side wears it out more
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-13-2004, 04:22 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
As has been pointed out before, if the truck is a 73-87, the gas tanks can cause it to lean one way or the other based on how much gas is in each tank.
When you measure, make sure you measure from the fender lip to the bottom of the wheel. That way, if the tires are not aired up evenly you still get a consistent measurement.
All vehicles are off by a little bit, typically. You don't notice it until you start making changes to the suspension, then it becomes apparent. I measured mine last night, and the two sides are off by about 1/4 inch. EVERYTHING in the front suspension is new. Everything has zero miles on it except the springs, which have about 500 miles on them.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-13-2004, 08:48 PM   #4
cochran63
cochran63's Avatar
1/4 sounds pretty good to the 3 inches that my 85 swb was leaning when i bought it.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 01-13-2004, 09:49 PM   #5
Slonaker
Slonaker's Avatar
Certainly. My point was that, even with new parts, it still is not likely to be perfect.
I hope you got a good deal on it.
Slonaker
Stock '01 Silverado
Old 01-14-2004, 11:09 AM   #6
alf4444
alf4444's Avatar
Slonaker
I think you mean fender lip to center of hub to get a consistant measurement.
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 01-14-2004, 11:52 AM   #7
Slonaker
Slonaker's Avatar
The distance from the center of the hub to the bottom of my wheel never changes. Does yours?
Slonaker
Stock '01 Silverado
