Old 08-07-2014, 03:48 PM   #1
blown240
blown240's Avatar
Sending Unit Question
I need to get a new fuel sender in my 61 Panel because the float crumbled. The sender and the gauge are not stock. When I check the resistance on the sender I get 30-800 ohms. That seems odd to me. Shouldn't it be 30-240?
I need to get a reading to see exactly how much resistance it takes to get the gauge to read full and empty.
blown240 is offline   Reply With Quote
Old 08-07-2014, 03:56 PM   #2
slepysal
slepysal's Avatar
Re: Sending Unit Question
stock should be 0-30 ohms
yours will be what the after market gauge is set up for. What brand is it ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-07-2014, 04:08 PM   #3
blown240
blown240's Avatar
The gauge is Equus brand.
Here are some pics of what Im working with...
Old 08-07-2014, 04:25 PM   #4
slepysal
slepysal's Avatar
there should be a stamp on the sender that tells you the ohms.
IIRC the euqus should be a 0-90
you miight be able to get the float seprately
Old 08-07-2014, 04:27 PM   #5
blown240
blown240's Avatar
There are no markings on the sender. But my multi meter reads it as 30-800 ohms.
Old 08-07-2014, 04:33 PM   #6
slepysal
slepysal's Avatar
try this
http://www.equus.com/Support/Gauges
Old 08-07-2014, 04:45 PM   #7
blown240
blown240's Avatar
Thanks for the link. My gauge isn't listed, but ill hook up a potentiometer to it and see what readings I get.
Old 08-07-2014, 04:47 PM   #8
slepysal
slepysal's Avatar
one more thought, O'rielys ,and Autozone sell Equus. You could buy a sending unit from them and just use the float, that is if your sender still works. You will have to trim it but you could use your old one as a guide.
How long is your float arm, and were are you in Cali ?
Old 08-07-2014, 04:49 PM   #9
blown240
blown240's Avatar
Im in Fountain Valley, right next to Huntington Beach. I was thinking of just going to home depot and making a float from some copper pipe. I bet that a 3/4 pipe, thats capped on both ends would work.
The arm is about 6 1/2 inches long from the pivot to the 90 degree bend.
Ive got an O'rielys close by. Ill see what they have.
Old 08-07-2014, 04:51 PM   #10
slepysal
slepysal's Avatar
was the float just a little black plastic float or brass?
Old 08-07-2014, 04:52 PM   #11
blown240
blown240's Avatar
no idea. Ive only had the truck for 2 weeks and the fuel sender was in a box of random parts.
Old 08-07-2014, 05:09 PM   #12
blown240
blown240's Avatar
I just found this picture from a text the PO sent me. Looks like the fuel pickup is part of it too. and the pickup tube looks pretty bad.
Old 08-07-2014, 05:26 PM   #13
blown240
blown240's Avatar
I just went out with the sender and the multi meter.
Looks like empty is about 32 ohms, and full around 90.
Old 08-07-2014, 05:29 PM   #14
slepysal
slepysal's Avatar
Yup he used the oe pick up and and the Equus sender.
Old 08-07-2014, 05:32 PM   #15
blown240
blown240's Avatar
I think I may need to make a new pickup tube.
Old 08-08-2014, 12:31 AM   #16
Captainfab
60-66 Nut
If you can't determine what sender the gauge needs, you may have to buy a new gauge and sender. Then rebuild the original pickup tube with the new sender. If that is something you don't want to deal with, contact member Vin63 here on the forum. He builds custom fuel sending units.
Old 08-08-2014, 10:58 AM   #17
blown240
blown240's Avatar
Thanks Captainfab. I'm 90% sure a 0-90 ohm sender will work. Im going to start there.
Old 08-11-2014, 06:00 PM   #18
slepysal
slepysal's Avatar
so any updates on it ?
Old 08-11-2014, 06:11 PM   #19
blown240
blown240's Avatar
I couldn't get the correct sender locally, so I went and got a sender that I will steal the float off of. And I got some brake hard line that I will use as a pickup tube. I just need to get time to hook it all up. Im having some carb issues too, but thats another thread.
Old 08-12-2014, 07:00 PM   #20
blown240
blown240's Avatar
Looks like I got this working.
I ended up getting a sender locally even though I knew that the OHM rating wasnt correct. I used the mechanical part of the old sender, with the new float and the new top plate. I had to weld the holes in the top plate closed and drill new ones so that there was room for the pickup tube. I used a piece of brake hard line for the pickup tube. Once I know that it all is solid, and my gas tank doesn't leak, I will JB weld the top of the brake line to the top plate.
I got it all hooked up and it appears to be working.
Here are some pics:
Old 08-12-2014, 07:59 PM   #21
slepysal
slepysal's Avatar
Right on man looks like a good fix!
Old 08-12-2014, 10:10 PM   #22
blown240
blown240's Avatar
Thanks sal
