Old 07-28-2014, 08:11 PM   #126
rip2174
Re: 83/84 swb stepside long time build
Now I need to clean up my garage. So things will be on pause for probably a week or two. By then hopefully the other truck with motor shows up so I can start putting together a truck. LOL
rip2174 is offline   Reply With Quote
Old 07-28-2014, 08:13 PM   #127
rip2174
Originally Posted by jpnh View Post
getting closer. looks good-jeff
Thank you
Old 08-05-2014, 08:35 PM   #128
rip2174
Ran into some issues with the front shocks this past week. Got with Nate and he is going to try and help fix the problem. I really like Porterbuilt's customer service. Meanwhile I've started on installing the Accuair e-level system today. This will probably take me a little while. when I get a few things done I'll post a couple of pics. Really like the quality of the product that Accuair puts out. The system was nicely packaged with some pretty excellent diagrams.
Old 08-07-2014, 07:20 PM   #129
rip2174
Here is the rear sensors mounted. Need to tweak the linkage a little to get it more centered. Didn't get the full 2.75 recommended. But it is over 2.5. About the best place I could find to mount the sensors. Having a little difficult time finding a spot for the front ones.
Size:  32.3 KBName:  IMAG0243[1].jpg
Old 08-12-2014, 04:44 PM   #130
rip2174
Ok getting the front end back together. Can't afford to upgrade brakes right now. Went with the CPP drop spindles. Had to buy the HD 1.25 rotors to go on spindles. Was told I could use stock calipers , just needed to order a bracket from CPP to attach stock calipers to spindles. Attached bracket and calipers with new pads wont fit over the rotor. Gap between pads fully retracted piston is 1.125. Do I need different calipers? Any feed back would be nice.
Old 08-14-2014, 07:22 PM   #131
rip2174
got the HD calipers and everything lined up and went together well. Heres a couple pics . Also got the front height sensors mounted.
Size:  33.1 KBName:  IMAG0246[1].jpg
Old 08-14-2014, 10:33 PM   #132
aotte1
It is looking very nice, you really come a long way, with a great build.
Les
PM sent on 220
aotte1 is offline   Reply With Quote
Old 08-28-2014, 06:55 PM   #133
rip2174
Les
PM sent on 220
Thank you Sir. And thank you for the welder advice.
Old 08-28-2014, 07:06 PM   #134
rip2174
Well I got most of the front stuff installed. The Accuair sensors. The rack and pinion.
Old 08-28-2014, 07:10 PM   #135
rip2174
got to the sway bar and thought I'd get a few questions answered. the brackets line up with a hole in the frame in the front hole. Should I use these and drill the rear holes? the holes are a 1/4 in difference off the front of the frame.
Size:  42.5 KBName:  IMAG0257.jpg
Old 08-28-2014, 07:13 PM   #136
rip2174
got this with the sway bar kit. Got to say the instructions are pretty vague. Should this bracket be under frame between the frame and the U bracket holding the bushing?
Old 08-28-2014, 07:18 PM   #137
rip2174
Nate from Porterbuilt got back to me today about the angle of the front shocks. He said he'd be unable to make new brackets and that I'd have to move the shock brackets forward. So know I have to take those off, cut most of the old shock mount out and move the brackets up. Wouldn't be so bad except I just painted. LOL Still impressed with Porterbuilt's product and their customer service.
Old 09-19-2014, 07:06 AM   #138
rip2174
Well. Its been a few weeks and Ive been dragging my feet. had to remove front shock mounts and move them forward about an 1 1/4 in. Had to cut out the stock bump where the shocks use to bolt to.
Old 09-19-2014, 07:08 AM   #139
rip2174
got mount mounted back up and shock close to the 3/8 that Nate suggested from the upper control arm bolt.
Size:  78.8 KB Name:  IMAG0271.jpg
Old 09-19-2014, 07:14 AM   #140
rip2174
put 2 washers in lower shock bolt and now the shock bushings are in better shape.
[ATTACH][ATTACH]Name:  IMAG0274.jpg
Size:  25.4 KB[/ATTACH][/ATTACH]
Old 09-19-2014, 07:16 AM   #141
rip2174
Wanted a little up grade in brake lines. Got some braided brake lines from Azproperformance.
Old 09-19-2014, 07:21 AM   #142
rip2174
For now im just painting old wheels.
With or w/o?
[ATTACH]Name:  IMAG0269.jpg
Size:  90.5 KB[/ATTACH]
Old 09-20-2014, 03:02 PM   #143
Hankster
Hankster's Avatar
I was planning on painting mine black and running chrome center cap and no ring, but now I'm going white.. So If i was you, I'd run center caps, and no rings.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 09-27-2014, 05:38 PM   #144
rip2174
definitely center caps.
Old 09-27-2014, 05:41 PM   #145
rip2174
Ok went out today to finish mounting the sway bar. Got it all in place and aired the frame out and noticed that the passenger's side is slightly higher than the driver's. Checked to make sure all air was out and stood on frame to get it to drop, but seemed to be bottomed out. the sway bar seems to be off. so I took a few measurements and it is out like 1/2 inch. posting some pictures. can any give any advice why the frame isn't laying level side to side?
Old 09-27-2014, 05:43 PM   #146
rip2174
[attach]
Size:  35.8 KB[/attach]
Old 09-27-2014, 05:44 PM   #147
rip2174
[attach]
Size:  46.5 KB[/attach]
Old 09-27-2014, 05:45 PM   #148
rip2174
Old 06-17-2015, 10:09 PM   #149
rip2174
Well its been a bit. Was pretty depressed when I felt I hit a wall with frame and the old truck. Guy finally told me other old truck was almost ready. I had to take some time off with that and school and work meeting high demands
Old 06-17-2015, 10:12 PM   #150
rip2174
Got the other truck back. Highly disappointed with what I felt was a good project truck coming back and the money I spent for the new vortec. The truck is in real bad shape. He must have stored it under a tree for the last 13 years. All kinds of rust! that wasnt there before, lots past what I feel my body skills are.
