Old 08-03-2014, 08:46 PM   #1
davepl
davepl's Avatar
How close it too close?
My exhaust was installed by the body shop long before I reassembled the truck (frameoff teardown). As a side-effect they didn't take into account the parking brake cables and the tank fuel line.
The plastic-coated parking brake cables, even after re-routing one side, are about an inch away (sideways) from the pipes.
The rubber section of fuel line that runs between the cab line and the frame line (it's there for flex, I imagine) is 1.5" above the exhaust pipe.
On the plus side, this is about mid-truck, so it's not just off the collectors or anything.
I wrapped each of these sections with DEI Titanium Exhaust wrap (woven from lava rock fibers!). It withstands 1800F direct and 2500F intermittent, but its really more about insulating the rubber hose for me.
Is an inch and a half air gap enough with an insulated pipe? I figure at idle when no air is moving its under very little load, and under a lot of load it'd have a lot of airflow. But it's really a SWAG.
I also added a reflective heat tube around the fuel line. So they're both insulated and now with about an inch air gap. And I suppose the fuel hose gets cooled by fuel, though not much at idle.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-03-2014, 08:57 PM   #2
El Campo
El Campo's Avatar
Re: How close it too close?
Good question! Curious to see the responses on this one.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 08-03-2014, 10:29 PM   #3
davepl
davepl's Avatar
I wouldn't mind seeing how close they were from the factory. My exhaust isn't unreasonably high in the chassis, I don't think. If someone can measure or get a photo, I'd sleep better. Or worse. But at least I'd know.
Old 08-07-2014, 09:34 PM   #4
davepl
davepl's Avatar
No answers yet. Did the factory even run dual exhaust, and if so, how did they get the pipe through there while keeping it away from the rubber line?
Old 08-07-2014, 09:52 PM   #5
71 super
71 super's Avatar
. It looks like yours is above the crossmember, the factory did not do that. I will snap pics of my bb truck in am for you.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 08-07-2014, 10:16 PM   #6
davepl
davepl's Avatar
It is - sort of through the crossmember actually. Would very much appreciate a photo!
Old 08-07-2014, 11:06 PM   #7
FirstOwner69
FirstOwner69's Avatar
Only the big blocks such as yours had duals. The small block single pipes ran down the left side.
Most small block owners have probably converted to duals as I did. My right side is basically a mirror image of the left. I assume your leaf spring truck pipes would be the same to the rear of the crossmember that supports the driveshaft carrier bearing and that they are different from that point back. If that is correct, the pipes should run below both of those crossmembers. My right pipe is about 6" below the rubber line that connects the tank fuel line to the frame line.
Below are the best pictures I can find in my file. I've zoomed in for clarity. The red dot at the center right edge of the first picture is a cap on the fuel line. It can also be seen near the top of the second picture.
Regarding the parking brake cables... Mine are the originals (3/4 ton with TH400). As you can see in the pictures, they are not plastic coated. The Longhorns may have been different, but, other than length, I'd doubt it.
Jim
FirstOwner69 is offline   Reply With Quote
Old 08-08-2014, 07:43 AM   #8
The standard that exhaust shops go by is 1" minimal clearance on gas tanks,from my experience. I have Air Lifts on my K3500 and the exhaust passes about an inch from the passenger side bag. They did provide a light gauge aluminum heat shield to put on the pipe. But no problems with that. The further back the better due to cooling of gases
Old 08-08-2014, 10:11 PM   #9
71 super
71 super's Avatar
Dave this is very bad picture but hopefully you can see how low the factory dropped the exhaust under crossmember and it angles up and dog legs just past the mid cross member so it is never near the fuel line. Sorry for crappy pic the iPad and dark garage equals bad. Pipe drops off head pipe and basically runs parallel to frame til mid crossmember
Old 08-08-2014, 10:57 PM   #10
davepl
davepl's Avatar
Looks like my two options are new head pipes to drop it below the crossmember or to try to increase the clearance.
I did the latter today - loosened all the hangers and clamps and fought with it until I got about 2" (exclusive of the heat wrap and shielding).
SpecialK - when you said 1", was that for the metal line or near rubber? There usually is a section of rubber back at the tank on cars, so I'm not sure which you meant.
Old 08-08-2014, 10:59 PM   #11
davepl
davepl's Avatar
For what it's worth, I found this:
http://gibsonperformance.com/product...str_mnl_01.pdf
"MAKE SURE
YOU HAVE A MINIMUM
OF A 1” CLEARANCE ON
ALL PIPES FROM ALL
RUBBER BRAKE LINES,
TIRES, SHOCKS, FUEL
LINES, ETC. THEN
TIGHTEN ALL CLAMPS
AND HANGERS"
Old 08-09-2014, 09:37 AM   #12
That's what I meant,and that's with no shield. Sounds like you have it?
Old 08-09-2014, 02:41 PM   #13
davepl
davepl's Avatar
If they're ok with 1" from rubber, I'm much better off than that. I wonder about using steel braided line instead. I could at the extreme transition from hard line double flare to AN, use braided line, then AN back to double-flare. A lot of work to flare in place, would require I drain the tank again. and if you mess up once there's no extra line coming out of the cab to "try again".
I wonder if there's a cheap remote sensor I could stick on the hose for a couple of weeks just to see what range it's operating in, then I'd know.
