Old 08-08-2014, 10:25 PM   #1
'65 chevy lover
One or two piece driveshaft?
After much flip flopping between a TH350 with lockup and a 700r4, I finally got a transmission ( TH400 with short tailshaft ) and, need opinions about a driveshaft. Obviously, I want the strongest DS I can get. I'm wanting to know if I should try and go with a two piece DS or, go with a one piece. The truck is a '65 longbed and the motor is a 383 stroker with 450 HP and 454 ft/lbs torque. Current setup is two piece with carrier bearing and the carrier bearing mounts using inline bolts ( not u-bolt style ). I understand that one piece DS is most likely stronger but, not sure if it will work with my setup. Truck is slightly lowered ( 2-1/2 drop spindles front and, 2" lower springs rear ). Thanks in advance for any help. I would really appreciate it!
'65 chevy lover is offline   Reply With Quote
Old 08-09-2014, 07:06 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: One or two piece driveshaft?
Ft Worth Gear and Axle right off of north 35. Go see them. They've built all my driveshafts for the last 20+ years. They'll know the best path for you to take.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-09-2014, 10:30 AM   #3
Keith Seymore
Keith Seymore's Avatar
I always prefer a one piece when I can get away with it (ie, if it will physically package). Less mass and less complexity, fewer moving parts.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
