#23 |
60-66 Nut
Re: broken rocker arm stud
If those are indeed 882 castings they will have ~76cc chambers. If you have flat top pistons that will give you around 9:1 static compression. Then if you figure in your big cam, your dynamic compression will be way too low.
| Bookmarks |
