Old 08-11-2014, 09:43 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Need Factory 15 inch Rims Identified
Looking at a truck ( yes already ) and these are the original rims. The seller says they are split rims. They are on a 1969 C10 and the spid says
Kelsey 15 x 5.5 F rim
Hs anyone sen 15 split rims on a C10.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-11-2014, 10:09 PM   #2
boynton
boynton's Avatar
Re: Need Factory 15 inch Rims Identified
I personally do not have knowledge of these but I have heard of them and heard they are not the best option (no personal experience). I am in for the education as well!
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 08-11-2014, 10:44 PM   #3
chewychevy67
My 67 came with those. I chucked them. No one would work on them here. Are you free this week . Ill bring the lense into the city with me. If you want to pick it up from on wed to fri I will be working on vancouver ave.
chewychevy67 is offline   Reply With Quote
Old 08-12-2014, 12:22 AM   #4
Already Gone
Yes I can pick it up on Wednesday. I'll call you for the address on Wednesday.
Old 08-12-2014, 12:54 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
My '68 C/10 Stepside came with 17.5 x 5.25 6-Lug rims like that. I wore 'em out after only 300,000 miles. Couldn't find the 17.5 size rim any more. Went to 16 x 7 6-Lug. Original tires were 7.00 x 17.5. They got scarce in the late '70s. Ran 8.00 x 17.5 Bias then R8X17.5LT radials when they came out. Now I have LT235/85R16 all around.
Old 08-12-2014, 08:01 AM   #6
Yes,I've seen those on these trucks. Most have been changed at this point. They are a great sign of a truck not altered much. Watch,now you'll show the rest of the truck and these wheels will be the only thing left original. My friend when I lived in CA had a '57 shortbed 8-lug with 15" split rims. Must have been special-built,but it was certainly very original.
Old 08-12-2014, 09:17 AM   #7
Already Gone
Thanks for the info. The wheels are sitting in he back of the truck they came off and except for the rallys replacing the original wheels the truck is very original.
Old 08-12-2014, 03:32 PM   #8
Have you had a look at the SPID? It's the tires that will be listed as the option,not the wheels. The wheels were just what was required to run a given tire spec. Is that Turquoise Poly paint or is it just my monitor?
Old 08-12-2014, 05:43 PM   #9
Already Gone
Here is the Spid. The rims are list a an option and there is nothing about tires.
Old 08-12-2014, 05:44 PM   #10
Already Gone
Couldn't load two pics together today so here is the truck.
