10-05-2008, 10:29 PM | #1 |
2WD Jimmy
door jamb switch installation
OK... how do these things go in? There was no nut with the switches, so I purchased some jamb nuts... How do you reach the backs of the switches to get the nuts on? much less reach the switch with the wire. Shoot, I pulled the old ones off there over five years ago.... Im stumped.
TIA, Tom |
10-06-2008, 05:06 AM | #2 |
Re: door jamb switch installation
The original switches had a fine thread male end on them that screwed into the tapped hole in the door post.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
10-06-2008, 08:33 AM | #3 | |
2WD Jimmy
These switches, and the harness, are from American Aurowire... if that helps. Last edited by Tom Vogel; 10-06-2008 at 08:34 AM. |
10-06-2008, 08:48 PM | #4 |
2WD Jimmy
Cmon guys, sombody knows the answer.
10-07-2008, 09:45 AM | #5 |
It's a catastrophic success.
IIRC, you push the wire through the hole first. You hook it to the switch, then screw it into the hole in door jamb.The switch should thread into the hole with no nut.
10-07-2008, 10:01 AM | #6 |
i second Sneakysnakes answer
10-07-2008, 12:27 PM | #7 |
Firefighter
You have to hook up the wire first, then screw it into the door jamb.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
10-07-2008, 10:16 PM | #8 |
Use a fish wire to pul the wire through the hole first, attach the wire to the switch and then thread the switch bach into the threaded hole in the door jamb. From there it is a s simple as hooking the switch wire in series to the dome light/cargo light if equiped.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
10-08-2008, 12:01 AM | #9 |
2WD Jimmy
Wow... darnit. These switches and the small wire loom that goes with them came from AAW (they look great btw). There dont appear to be any threads in the hole in the door jambs... More importantly, the threads on the switchs dont go all the way to the base/hilt of the switch... so... if you screw the switch in to the stop, the switch just rattles loose from side to side. I wish I could get my pictures down sized enough to fit them on this site... Ive got a new (actually older) camera that have a lower pixel size, so maybe that will work. Then I could post a picture of the switch.
10-08-2008, 08:52 AM | #10 |
You can use "paint" to resize your pics.
Here is a pic I found of the switches http://www.manestruckparts.com/store...&Category_ID=8 |
10-08-2008, 10:18 AM | #11 | |
2WD Jimmy
03-26-2013, 09:05 PM | #12 |
you have to tap the drilled hole with a tap &die bit.then the switch screws into the newly made threads.
08-15-2014, 01:30 PM | #13 |
so the wire that goes to the switch, is that the negative for ground that activates the light?
08-15-2014, 01:33 PM | #14 |
if that is the case where the switch grounds creating a closed circuit for ground, then you must need a seperate power feed for the light itself because the power to the light now is created by the potientometer within the light switch. CORRECT ?
08-15-2014, 02:14 PM | #15 |
The Older Generation
I just posted these in another thread. I will post them here too. This is an original setup. LockDoc
08-15-2014, 02:26 PM | #16 |
To the above, yes. The courtesy light circuits are on BAT (+) meaning they have 12V at all times regardless of whether the key is on or not. The various means of turning on the courtesy lights (primarily the door pins or headlight switch) connect the lights to ground via the white wire.
Normally orange is the positive, white the negative.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
