Heavy Machines powered by GM diesels or Detroits
I'm not sure if this belongs here or not but they sure are heavy they weren't made by the general but they needed a reliable heart with a great service network let's talk about the heavy trucks, tractors, cranes, ect. with GM hearts the first one was John Deere's second attempt at a 4 wheel drive tractor the recalled 8010's (the tractor in the 2nd pic) were upgraded with better seals between the 6 cylinder Detroit and the 8 speed road ranger I believe? and a better oil pump and something to do with better cooling it could pull an 8 bottom plow a 7 mph and back then they cost brand new in 1960 $30-35,000 dollars the third and fourth pic is the one year only made equipped with a 2-53 2 cylinder GM Diesel engine
#2 | |
Re: Heavy Machines powered by GM diesels or Detroits
I never knew they made one until I was over at a guy's house one day who has a bunch of old trucks and equipment, back around '92. He was showing me his collection and mentioned something about a Detroit and the John Deere. I saw the Tractor and was looking around for the Detroit. I walked back over to him and said, "I saw the John Deere, but didn't see any Detroit near it". He then said "No, the Detroit is "in" the John Deere". Well being an old Detroit fan and a recent John Deere fan, I couldn't believe it. Asked him about selling it, as I was looking to soon replace my little '46 Ford 2N, but we never got together on it. In '99 I made up my mind to replace it for sure and found one nearby for a reasonable price. Mine is a '59. (They are all Model 435's). Bill
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
Oliver had the model 99 that was Detroit powered.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
I believe the Oliver has a 3-71.
I've seen them at the Tractor Pull and they sure do sound sweet, especially with a Straight Stack like the one above. Bill
The Super 99, updated 990 and 995[with Allison torque converter] all used the 3-71 , plus Oliver made the Massey 98. The 6V71 fits in those chassis as well.
The 2-53 in the Deere 435 is derated to try to preserve the final drive, small injectors, no oil cooler, special water pump. |
here are some pic of the P&H T-300 30 ton boom crane my parents have one that I do not have pictures of I don't know the transmission on it although it is a twin stick and it has a Detroit Diesel I don't know what it is but she does your typical leaking when stored for the winter lol
At the body shop.
![]() Hay squeeze
" That didnt make it any newer " " Dont antique the equipment " |
At the body shop.
Lots of GM-powered equipment out there,especially diesel. It seems Detroit was a favorite for fire trucks and mobile cranes. Then,there were GM's own heavy equipment companies. Next we'll have to do a thread on GM-powered boats
They say Detroit Diesels helped win the War!!
Seeing that they were first out in '38, they were all ready well established by the time they were needed for war in late '41. A list of uses all through the years: -Trucks -Buses -Tanks -Ships -Boats -Generators -Pumps -Tractors -Dozers -Loaders -Backhoes -Cranes -Forklifts (keep adding to the list)
How about heavy machinery powered AND built by GM? The Euclid TC12 was the baddest crawler tractor on the planet starting in '55 (55-68-Euclid/68-74-Terex). Twin 6-71s and two Allison 3spd Torqmatics mounted in a split frame that allowed each side to oscillate over uneven ground. Suspension...what? The controls required were but simple. Two levers and two pedals. One pedal each side for brakes and one lever each side controlled steering and throttle for each engine. Steering was done by the amount of throttle to each side. So it could spin on a dime with one throttle forward and one throttle back. I've herd guys talk about these for years and there's a lot of love out there for these,yet. I spotted one along the hiway on our way up to Macungie this year. Hmmmm.... How bad do I need that?
Here are some pics of the John Deere 440 industrial 2 cylinder crawler and wheel tractor the were offered with your choice of 3 different engines either the extremely rare all fuel model, gasoline model, or the 2-53 GM Diesel engine. various equipment options could be had such as dozer blades, loaders, pipe laying cranes ,cable layers they also could be had with a direction reverser and pilot touch control was available on the crawler models it eliminated the dual control levers for a single control lever but it did not do very well and constantly needed adjusted and was recalled and the dual control levers were installed
Euclid...GM 1953-1968 till the Fed made them change things up,which is when Terex got started. I grew up with Euclids and was fascinated by them.
![]() Join Date: Aug 2005
All very impressive, but I think I have you beat:
http://www.oerm.org/collection/santa-fe/atsf-98 Don't forget, GM founded EMD, one of the largest manufacturers of diesel-electric railroad locomotives. This particular locomotive is an FP45 from 1967. It has a turbocharged 20 cylinder EMD 654 diesel of 3,600 h.p.. These engines are similar to Detroits in that they are 2 stroke, and the '654' designation stands for the cubic inch displacement of one cylinder! I volunteer at that museum, and have had the pleasure of not only working on that particular locomotive (it is currently being restored) but operating it as well.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
#15 |
Dang Bob,I knew they had major power and major engines but you put it all in perspective. That's huge! (and a handsome devil,too)
#16 | |
Glad you enjoyed it, Bob.
#17 |
What i always found ironic was the fact that ford used detroits alot in there big trucks, seen tons for sale, but i guess the saying is true, fords run better with gm parts.
1998 Ford Ranger FX4, 3.0 V6, 5 speed manual 1999 Ford Explorer, 4.0 V6, 5 speed auto O.D. 2005 Chevy Colorado, 3.5l inline 5, 4 speed auto 2001 Gmc sonoma 4.3l V6, 4 speed auto soon to have 1981-88 k30
#18 |
Yeah, Ford got their share of Detroits, but you could actually get one in just about any truck, American Made anyway. I've seen some interesting combinations, although not real sure they were all factory, but a Detroit in a B-Model Mack is pretty interesting and I've also seen a 6-71 in an R-Model Mack. They put plenty of 8V-71's in them, but a 6-71 is pretty rare in an R.
#19 |
One thing ive noticed with the older trucks is they may have offered various brand (cat, cummins, detroit) but it always seemed one manufacturer preffered one brand, like the older IH trucks, they offered those 3, but it seems like the cummins was the most popular for them and older kenworths, and cat was the most popular in peterbilts.
#20 |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 09-15-2014 at 06:13 PM. Reason: smaller pic |
#21 |
I believe that would mow my fields with no problem, lol.
#22 |
At the body shop.
The song that could sing...
#23 |
Many a new Ford car was delivered to the dealership on the back of a Louisville Ford powered by GM's Detroit Diesel. That's why GM is great. They make/made more of their own stuff...and stuff for other makes...than the others. Ford and Chrysler made less of their own truck than GM. Look back to the early days of diesel heavy trucks and you hear about those GMCs right along with Mack,White,Peterbilt,or any other. You don't hear raves about how great the Fords and Dodges were. To this day, with the companies only making light trucks, Ford uses International and Dodge uses Cummins and GM makes their own. Then,there were the Allison Transmissions (and aircraft engines). But, GM sold that in '07
#24 |
Its too bad gm didnt get more into the ag market, if they made tractors, they would have been some of the best.
#25 |
The early venture in the Sampson was GM's tractor .
| Bookmarks |
