Old 01-15-2004, 02:03 AM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
Milemarker kit for 203 part time 35 bucks
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2454433639
Hmm. I thought these were 200 bucks. It has a 60.00 price tag on it, maybe the tag is 20 years old??
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 01-15-2004, 02:11 AM   #2
1FaastC10
1FaastC10's Avatar
anybody ever installed one of these? my 10 bolt front already has locking hubs, so all i would need is the kit to convert to part time. what are the advantages of being able to run in 2wd? is gas milage really that much better?
1FaastC10 is offline   Reply With Quote
Old 01-15-2004, 02:34 AM   #3
Scrub
Scrub's Avatar
Well, you could lock you hubs in and drive in 2wd and then put it into 4wd on the go. now you have to get out and lock the hubs in to get into 4wd. Your driveline will last longer and your gas mileage will improve. Seems like it would well be worth 35 bucks. I think this will go fast. If you want it, I would buy right away.
Scrub
Old 01-15-2004, 02:52 AM   #4
1969 GMC
1969 GMC's Avatar
not to mention you get a better turning radius when in 2wd.
i have heard that you need to run the t case in 4wd every once and a while to splash some lube around inside the case.
i'd say go for it...that is cheap
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-15-2004, 03:02 AM   #5
1FaastC10
1FaastC10's Avatar
i do that with my 241C in my 91 about once a week, if not more. as for the 203, i dont think i'll have to worry about making it a point to put it in 4wd to "splash some lube around the case", it will spend plenty of time there for more serious reasons.
Old 01-15-2004, 09:53 AM   #6
1969 GMC
1969 GMC's Avatar
good for you, no "mall posers" here at all.... :p
1969 GMC K2500
1996 Honda Accord
Old 01-15-2004, 10:48 AM   #7
smokekiki
Mike
smokekiki's Avatar
The prices for the milemarker kits in summit are $39.95 without hubs and$95.99 with hubs.It is well worth it in my opinion.My truck turns better and less wear on the front tires.Milemarker says to put it in 4wd about every 200 miles.All you have to do is shift the case into 4wd for a few miles.It took about 3hrs with the new hubs to install.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 01-15-2004, 10:51 AM   #8
smokekiki
Mike
smokekiki's Avatar
Also,go to www.coloradok5.com there is an instal on thier site.The guy who wrote it up has some very good info.He changes the instructions to make it easier.Look under product review.
Old 01-15-2004, 11:56 AM   #9
Scrub
Scrub's Avatar
OK, If they are 39.99 at Summit then this is an OK deal, but not considered legal theft or anythng. I thought they were more money.
Scrub
Old 01-15-2004, 12:14 PM   #10
smokekiki
Mike
smokekiki's Avatar
Right now it is a 35.00 buy it now price.If interested,I would bid on it.If you lose,you know You can get one for 40.00.Even at the 35.00 it's not bad if you are sure it is all there.The prices are more than half of what they were 20 years ago!I had a 78 ford that I put a milemarker kit in,in1982.I am sure it was close to $200.
Old 01-15-2004, 01:10 PM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I believe they have two different kits one more in depth than the other. Could be wrong though.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-15-2004, 05:33 PM   #12
smokekiki
Mike
smokekiki's Avatar
The one in the auction is a 501 kit,it comes without hubs.The 502 kit has hubs.There is also a kit that replaces the output shaft.It is the best because it removes some of the play in the driveline.It is also in the $200-300 price range.Milemarker also has a kit to take the play out of a higher milage chain.Also have new chains.
Old 01-15-2004, 05:51 PM   #13
1FaastC10
1FaastC10's Avatar
well, my front axle already have hubs, so i should be good with this kit. i think i might go ahead and spend the extra $5.00 and buy one from Summit if they're only $40.00. if i buy from them i'm guaranteed to get all of the parts, plus a reciept so that if anything goes wrong, i can send it back.
