Old 08-18-2014, 08:44 AM   #476
texasld
texasld's Avatar
Re: Br3w City's Project omgwtfbbq
Originally Posted by BR3W CITY View Post
Thanks guys~!
The exhaust in that location is give and take. If you position the tips long engough and with enough angle, the force of the exhaust blows MOSTLY past the fender. However, when i shortened the tips up a little, I did notice some discoloration on the paint. Nothing permanent, just obviously dirtier when you wash it.
However, if your running real rich or cold starting, AND have short exhaust tips, AND didn't wash it often, I'm sure you could stain the paint in some way...kinda like cigarettes on teeth.
The other things to keep in mind are; that style exhaust runs OUTSIDE the fender, has NO crossover, and is limited to bullet mufflers. You can use a similar exit without using the entire style of exhaust, but the "J-Turn" to get the exhaust through the side is tricky.....the actual layout of things results in some tighter bends than are ideal. When I re-do it in mandrel, we are trying to take some of the sharp turns out of the path. Also, it drones a LOT on the hwy.
Do you think it drones a lot because is bouncing off the rear fender. I'm going fleet side. Wondering if it will cause a problem. The heat has no effect to the paint so far?
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 08-18-2014, 11:41 AM   #477
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Well it doesn't bounce off the rear fender...it passes through the step, but doesn't really touch the step or the fender.
The droning is the result of running an LS motor with no crossover, small bullet resonator/mufflers, and a sharp-turning exit that lands directly behind the cab.
To eliminate the drone, I need to go mandrel bent, add a crossover, and possibly change the muffler style.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-18-2014, 11:47 AM   #478
texasld
texasld's Avatar
I meant the sound waves bouncing off the fender. But that is some great info for when I get my LS fitted and the exhaust run.
1999 Jeep TJ
Old 08-18-2014, 03:50 PM   #479
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Well if you could dye the exhaust, the actual angle of the exhaust points past the fender. I'm sure it can echo a bit, but you don't really hear "body" drone, its purely the sorta-unusual sound of the shape and type of exhaust.
Old 08-18-2014, 05:10 PM   #480
texasld
texasld's Avatar
Got ya! Thank you for the answers. I really want to do side exit exhaust, but I'm hesitant.
1999 Jeep TJ
Old 08-18-2014, 07:24 PM   #481
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
On a fleet body, you'll want to consider something like they use in boating. Its basically a "Bulkhead" exhaust tip. It bolts to the body with a stainless or aluminum shroud around the edge, giving you a clean exit instead of exposed-cut-sheetmetal.
Old 08-18-2014, 11:33 PM   #482
texasld
texasld's Avatar
That's exactly what I'm looking at. They look really awesome!
1999 Jeep TJ
Old 08-19-2014, 03:36 AM   #483
pdxhall
pdxhall's Avatar
those bulkhead exhaust ends are just what I've been looking for. Do you have more info on them?
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 08-19-2014, 03:53 PM   #484
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
They are dumb-expensive, and the easiest place to find them is boat-supply places. There are a few different kinds, and you gotta be a little bit careful.
Some of them have an internal "flapper" that swings closed when there isn't exhaust pressure coming out. Its a boat thing, but on a car it rattles and pings. Also, some hard-mount to the body, which means that you need a good mount/flex point in your exhaust or it will transfer a ton of vibration back into the body.
Old 08-19-2014, 11:10 PM   #485
texasld
texasld's Avatar
Here are some that I found. Reasonable price, I wonder about heat shield though.
http://www.buckhornperformance.com
1999 Jeep TJ
Old 08-25-2014, 05:34 PM   #486
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
A WILD project we did. This is another Plasti-Dip special, but we use a VERY special thermochromatic pigment....BCUZ HOTWHEELSCAR!
Old 08-29-2014, 04:47 PM   #487
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
A very cool truck I saw at a local cruise-in
And of course me taking pics of my own truck
Old 09-08-2014, 06:55 PM   #488
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Finally snagged my new-to-me heads from a friend. They are good ole 317's, but they've been milled a tad dropping the chamber by about 2cc's. They have also been fully worked...and I mean freakin worked...by a 40+ year veteran and instructor at S.A.M.
They have new gm valves with a full valve job, topped with Brian Tooley Racing platinum dual springs and Titanium retainers and all the other locks/seals/etc. I'm tempted to add new rockers as well when we open it up to eliminate the needle bearing concern. We ran and proved these heads on our fbody for a while and made excellent power.
Old 09-10-2014, 04:14 PM   #489
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
A followup to the ThermoChromatic dip video. A demo of the final result and playing around with the finish
Old 09-11-2014, 12:52 AM   #490
Chris Coufal
What paint is on the truck now? I'm really digging the satin theme
Chris Coufal is offline   Reply With Quote
Old 09-13-2014, 12:15 AM   #491
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks Chris. The truck is the same Satin Blue that its been for a couple years...
Are you asking what type of paint it is or am I reading something wrong???
Old 09-13-2014, 02:27 AM   #492
Chris Coufal
Yes sir....what type of paint.
Old 09-13-2014, 04:10 PM   #493
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its good ole' 3 stage paint, prime-base-clear. You'd paint it the same as any other car, but we used a satin clear (regular clearcoat with flattening agent).
Old 09-13-2014, 07:39 PM   #494
Chris Coufal
got it! Thanks!
Old 09-13-2014, 08:02 PM   #495
ChrisDollins
ChrisDollins's Avatar
Digging the truck and the vids. The heads look really good! Cool to see someone else from the fbody crowd.
Chris
ChrisDollins is offline   Reply With Quote
Old 09-13-2014, 11:11 PM   #496
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Chris
Hey Chris, if your an Fbody fan keep an eye on the youtube channel and here on my build. I'll be putting up some pics and video of that 'bird soon. We ran it at Gingerman Raceway this weekend, and the combo of big power and big brakes on stock suspension resulted in shearing the torque arm, and left peices of the 10bolt in the drain pan.
I'm fabbing a 9inch rear for it, and we are doing a full pro touring suspension in prep for next year.
Old 09-13-2014, 11:49 PM   #497
ChrisDollins
Awesome! (The car not the damage lol) Was it the stock torque arm? 9" will be nice. I've only ran the Moser 12 bolts, but the easy gearing changes with the 9" would be nice. It's been a while since I've done anything over on tech, but my user name is CHRIZ28 over there. Never did anything pro-touring, would be a blast though! Wanted to go more pt with the Firehawk, just ended up selling it. Would love to go pt with the 66. Just way more places to play on a drag strip around than autocross or road course around here.
Chris
Couple of my old Z28 passes
Old 09-16-2014, 05:24 PM   #498
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Very cool man. Here are some pics from the fiasco at Gingerman. I'll have to get my buddies cell phone pics that showed the sheared arm. You can barely see it in the side up picture. You can see where the wheel collided into the wheel well and ripped the undercoating off, and the rim scored it slightly above the shock. We were surprised this didnt' shred a tire or rip it off the rim...it was fine?
Old 09-17-2014, 09:45 PM   #499
ChrisDollins
Good looking car! I'll always have a soft spot for 4th gens. Time to get some suspension under that car for sure! I had really good luck with a spohn subframe mounted torque arm with two loops. Can't wait to see what you do with it. Oh, and the truck too lol. Do you post over on tech?
Chris
Old 09-18-2014, 01:08 AM   #500
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Chris
I lurk there for some info, but don't post there much anymore due to a number of individuals on that forum being so ignorant that they actively hurt the community with bad information.
Despite my mag credentials, and his (the t/a title'd owner) being a tuner and mech engineer for an OEM of GM...folks don't like to listen to advice or opinions that didn't fit the crowd.
We took engine dyno sheets from a cam we spec'd over their to share with some folks looking for advice. Despite hard #'s, we got **** on by posters because we second-guessed Pat G (and you know exactly how thats recieved over there). He re-spec'd a cam that matched ours in all but 1 dimension, and they fanboyed hard. I just can't do it over there.
Other than here, I like YellowBullet, since at least the poo-slinging is omni directional, and anyone with #'s or slips can make their own respect.
