Old 08-18-2014, 04:48 PM   #1
jh68c10
gear ratios
I have 12 bolt with this number. HA0402W2. I think it is 373 gear. My question is will 4.11 fit in this carrier?
jh68c10 is offline   Reply With Quote
Old 08-18-2014, 05:48 PM   #2
Turbo1dr
Turbo1dr's Avatar
Re: gear ratios
Check with the vendor supplying the 4.11's. They'll need to know the full details of the differential to make sure they sell you the correct gears that will fit.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored
1978 Turbo Malibu - Owned since 1986
1987 Grand National Aerocoupe -1 of 1
1988 LeSabre T-Type - Supercharged
Turbo1dr is offline   Reply With Quote
Old 08-18-2014, 06:35 PM   #3
67chevy1series
67chevy1series's Avatar
Re: gear ratios
There's a code on the passenger axle tube between the diff housing and the trailing arm mount. This code will have numbers and letters and will tell you the gear ratio and if it's posi or non posi from the factory... Be very careful... My axle said non posi 3.73, so I bought a 4 series posi carrier to put in.... Turns out somebody swapped in 3.07 gears in my axle... Long story short my axle is now back to being a 3.73.
67chevy1series is offline   Reply With Quote
