Old 08-18-2014, 08:51 PM   #1
Sean C
Question_My Truck Drives Sideways??
My brother was driving my truck and I was following in his car when I noticed that my truck looked like it was going down the road sideways. I could see the front drivers side tire from directly behind the truck. Can I fix this? Is this a major issue to tackle?
Hope this makes sense! I tried searching it, but couldn't come up with much.
Sean
Sean C is offline   Reply With Quote
Old 08-18-2014, 08:52 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: Question_My Truck Drives Sideways??
Frame bent?
DPowers is offline   Reply With Quote
Old 08-18-2014, 08:54 PM   #3
lazypineapple
lazypineapple's Avatar
alignment, ck Thrust angle
lazypineapple is offline   Reply With Quote
Old 08-18-2014, 08:56 PM   #4
pimpston65
pimpston65's Avatar
Originally Posted by DPowers View Post
Frame bent?
yup bent frame. kinda like a dog walking. or maybe the panhard bar is faulty??? but im thinking frame!!!
pimpston65 is offline   Reply With Quote
Old 08-18-2014, 09:00 PM   #5
66Submarine
66Submarine's Avatar
Leaf springs? Might have the rear end knocked out of alignment if so (mine does).
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 08-18-2014, 09:05 PM   #6
Sean C
Frame bent?
Could be the alignment. I don't think it was ever set after the Ididit steering rack went in. That was before I owned the truck.
Like a dog walking, you nailed it! As far as the panhard, I don't remember seeing it bent or anything. I don't have the truck at the moment otherwise I'd go crawl under there.
No leaf springs here
Sounding like a bent frame, which also sounds expensive...
Old 08-18-2014, 09:08 PM   #7
hotrod66
hotrod66's Avatar
mine did that i replaced track bar with a adjustable one. I also replaced the trailing arm bushings, rear springs due to them being pointed over to one side.
mine drives strait now. get a tape out and measure the wheel base side to side, if one side differs from the other it could be the trailing arm bushings.
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 08-18-2014, 09:10 PM   #8
AJNapierski
AJNapierski's Avatar
Mine does that a little the front was converted to leafs and they didn't line them up right
AJ
AJNapierski is offline   Reply With Quote
Old 08-18-2014, 09:13 PM   #9
Sean C
Good to know! My bed sits a little off kilter as well. New springs are ready to go in. I'll definitely be measuring the wheel base.
Old 08-18-2014, 09:17 PM   #10
hotrod66
hotrod66's Avatar
if the bushings haven't ben done just remember there almost 50 years old and they are cheep parts. nothing a saturday afternoon a hammer and some wood cant fix
Old 08-18-2014, 09:28 PM   #11
jtrichard
If you take a tape measure from the front fender line at the front of the doors to the front of the rear wheels i bet you that the right side is farther back than the left and since you said you don't have leaf springs that takes out a center bolt problem ...SO i would say your right trailing arm bushing is gone... or the right U bolts are loose and the axle has shifted some how (less likely) i doubt the pan-hard bar could be bad enough to make it DOG-TRACK that bad
jtrichard is offline   Reply With Quote
Old 08-18-2014, 10:04 PM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
If it's a stepside and only looks a little crooked, it can also be optics. Because the 1955 bed is too narrow for the cab, you can easily see the side of the cab making the truck look like it's dog tracking. Getting in the right lane and following behind the right rear tire can make it appear to be dog tracking the other direction.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-18-2014, 11:03 PM   #13
Sean C
Good call. This hadn't even occurred to me.
I have some measuring to do…I'll take a look at the U bolts as well as the trailing arms and see if those check out.
Not a step, but I definitely see your point. Parallax does some funny things
Thanks for all the advice guys! Feeling a lot better about it now.
Sean
Old 08-19-2014, 12:40 PM   #14
donthekawguy
donthekawguy's Avatar
Have it checked out but more than likely it's an optical illusion. If your in the right place at the right time any car or truck will look like it's crooked going down the road.
66 shorty
donthekawguy is offline   Reply With Quote
Old 08-20-2014, 02:01 PM   #15
jmack91z28
jmack91z28's Avatar
I would think it's an illusion too. My old 94 chevrolet had aftermarket wheels and larger all terrain tires, the wheels offset stuck the tires out more upfront than in the rear. Gave the illusion that it was driving sideways.
1961 C60 Viking 8' Dump 261 SM420 2-Speed Rear
1966 C10 Fleetside 350 W/ Saginaw 4 speed
1985 K10 Chevy 6.2 diesel 700r4 longbed
2001 Dodge 3500 Dually 24v NV5600 4x4
USMC Reserves
Jason
jmack91z28 is offline   Reply With Quote
