Old 08-16-2014, 05:01 PM   #1
72CampSpecial
What is this called and where can I order one..
So...HO52 rear end, '72 C20, replacing the bearings and brake shoes..missed this when i ordered new bearings and parts..
Is this a "Thrust washer"?? or something else..and where can i order one. As you can see the one on the top was damaged when the bearing ate itself.. the tab that holds this in place is gone..
Also, what oder do these go in? ...is this right? Washer on the left goes on the hub first then the nut, then the retaining ring, then the nut?
72CampSpecial is offline   Reply With Quote
Old 08-16-2014, 05:55 PM   #2
Acorn
Re: What is this called and where can I order one..
http://67-72chevytrucks.com/vboard/s...d.php?t=638542
Start here. I'm only familiar with the Dana 60 but that is the correct order to assemble. Good luck .
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 08-16-2014, 05:56 PM   #3
Wrenchbender Ret
That is the thrust washer. It goes together in the order you have them. A tang on the "spider" goes in a slot on the outer nut to lock it.
I might have one or the GM part number. I can look Monday.
George
Wrenchbender Ret is offline   Reply With Quote
Old 08-16-2014, 06:27 PM   #4
72CampSpecial
George
thanks.. that would be great..the guys at the "local" parts store all looked at me funny when i asked the what it was and could they order it.
Old 08-16-2014, 06:41 PM   #5
72CampSpecial
One more question.. what is the tool called that you use to tighten the two notched nuts? i was able to get them off with pliers and cussing.. but the install needs to be proper..
Special tool and tightened a certain amount, backed off to the nearest tab I'm guessing..
Old 08-16-2014, 06:59 PM   #6
69chevytrucker
69chevytrucker's Avatar
spin on by hand the use a punch and hammer to snug them up, bend a couple tabs over
69chevytrucker is offline   Reply With Quote
Old 08-16-2014, 07:07 PM   #7
69chevytrucker
called spindle hub nut and bridge nut tool
Old 08-16-2014, 07:11 PM   #8
69chevytrucker
stage 8 x-lock are said to be good google it
Old 08-16-2014, 07:27 PM   #9
davepl
davepl's Avatar
You can possibly rent the tool from a local auto parts store. I wouldn't monkey with trying to turn on it with screwdrivers and pliers, etc.
Glad I never had to do one of these, they look complicated compared to the Dana 60. I think it'd definitely be a good idea to have the workshop manual on hand, which likely has a diagram and steps.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-16-2014, 07:42 PM   #10
FirstOwner69
FirstOwner69's Avatar
Here's the one I got at Carquest. Best to use the right tool.
FirstOwner69 is offline   Reply With Quote
Old 08-16-2014, 08:54 PM   #11
Acorn
Read the manual! You can download a copy of it here on this forum.
You are supposed to tighten the first nut to a certain torque/preload then back it off like a half turn or something then re torque. Install your lock ring, then torque the outer nut. The manual gives you all the torque specs and how much you are supposed to back off and re torque. It can be done by feel but it's not something you want to experiment with on your first try.
Old 08-16-2014, 09:52 PM   #12
kwmech
Should be the same as a 14 bolt... dorman number 618-048, and the lock washer is a 618-049.
Old 08-17-2014, 10:50 AM   #13
72CampSpecial
Absolutely! I downloaded the manual a while ago.. but the picture that is shows is a sideways view of the whole hub assembly..based on that alone i wasn't sure if i had that part names correct..
I will use it though for the torque/re-assembly.. you are absolutely correct.. i don't want to over/under tighten this and dork it up.. especially with how hard it has been to get correct parts!
Old 08-17-2014, 10:51 AM   #14
72CampSpecial
thanks.. ill look that up..
Old 08-17-2014, 10:52 AM   #15
72CampSpecial
thanks everyone.. this is great help..
Old 08-18-2014, 04:21 PM   #16
Wrenchbender Ret
The GM part # is 3663658. I don't have any though. I have some of the spiders.
Check with your Chev. dealer. It might be available or they are all connected together on computers & a dealer may still have one in stock. You might check with Westfall GMC here in the K.C. area. They have a huge stock of GM truck parts.
Old 08-18-2014, 11:39 PM   #17
72CampSpecial
Thanks for checking.. ill order one tonight!
Old 08-19-2014, 12:32 AM   #18
70cst
70cst's Avatar
Guys ... Thanks for the great assistance
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
