Old 08-05-2014, 01:16 AM   #1
Madtrucker
700r4 shifting problems and swap advice wanted
I recently bought a 72 blazer with a 350/700r4/np205. According to the spid it originally had 305/4spd/np205. The 700r is giving me problems with short shifting from 1/2 and not up shifting into 3rd. There's no slipping or high reving it just stays in second and drives until I back off to keep the rpms reasonable. I have re geared to a 4:56 and realize the governor needs calibrated but don't see how that will fix 3rd gear. At wot it shifts at about 2400. All the trans shops are 3-4wks behind and I'm trying to keep my blazer going for the season. If no one can help it's on to plan B.
Plan B would be to swap the 700 for a 350, my question is how can I tell if my 205 was mated to the 4spd or came from a 350 trans. I don't know what was modified to fit, the 700 or the tc. All I know is there is a advance adapter spacer between the to. I'm not looking to spend $1700 or I'd have the 700r4 rebuilt so any help would be appreciated.
And I've looked locally for a 350/205 combo with no luck.
1968 k10 lwb-swb stepside
1936 chevy truck
1977 corvette
My 68 lwb-swb 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=527176
1972/68 blazer 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=641824
Madtrucker is offline   Reply With Quote
Old 08-11-2014, 05:21 AM   #2
Madtrucker
Re: 700r4 shifting problems and swap advice wanted
Anyone?
1936 chevy truck
1977 corvette
Old 08-11-2014, 05:28 AM   #3
andrewmp6
There's a few ways to do that trans swap,To know how it was really done pull your t case and count the input spline.There is a 10 spline a 27 spline and 32 spline.
Old 08-11-2014, 08:30 AM   #4
IIGW
Originally Posted by Madtrucker View Post
I. I'm not looking to spend $1700 or I'd have the 700r4 rebuilt
Anyone who is quoting 1500 to rebuild a 700 should stop drinking.
Pulling the overdrive trans out and putting in a 350 on 4:56 gearing will be like 3500 rpms at 65mph.
I don’t have my 700 manual with me, but if I were you id find another trans shop. Also, google the shifting problem ad im sure you will get all the answers you need asap.
Long run, that 700 is a non-electric version of the 4l60e. a good trans, with overdrive. Id keep it. In fact I have one in my 1 ton dually, on 4:11 gearing, and around 600hp at the motor.
IIGW is offline   Reply With Quote
Old 08-11-2014, 12:18 PM   #5
57taskforce
All about them K’s
57taskforce's Avatar
More than likely the 205 at least has a th350 adapter on it. Only way to really tell which case you've got is to pull it and count the input splines on the case. The easiest way to mate a 700r is with a 350 adapter and case. The easiest way is a 2" spacer between the trans and transfer case adapter, and longer bolts. although there are a few ways to skin this cat so it's hard to tell how yours was done without seeing it.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 08-17-2014, 08:06 PM   #6
Madtrucker
Thanks guys, Google has only led me to slippage problems in 3rd which I don't have. Trans doesn't slip, engine doesn't rev like there's no load, no burnt fluid.
The 1700 was more like a start over scenario like new trans, another tcase, driveshafts etc. I just figured someone would chime in with something like that.
I'm looking for a good local shop this week, hope it works out. Seems like people love or hate the 700, probably has a lot to do with the quality of the rebuild and installation. Seems like a lot of people throw them in and don't adjust the tv cable properly. Mine had a 350 kickdown cable rigged, but I changed that immediately.
1936 chevy truck
1977 corvette
Old 08-17-2014, 11:19 PM   #7
Madtrucker
I didn't mention I have 35" tires, so I don't think it'd run that high. I'll definitely calculate what it would run at with the 350 though.
1936 chevy truck
1977 corvette
Old 08-19-2014, 07:36 PM   #8
1malo68
1malo68's Avatar
Sounds to me like some sort of adjustment. Here's some good info that might help. I would definitely check the adjustment on your TV Cable to start with. Good Luck!
http://www.transmissioncenter.net/subject.htm
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
Old 08-19-2014, 09:31 PM   #9
Madtrucker
Thanks for the link, it seems to be set right but could be to late i suppose. I'm a little leery to try the 100mph test.
1936 chevy truck
1977 corvette
