MCGAUGHYS axle flip kit
I just finished installing my MCGAUGHYS flip kit 33156-1 on my '81 shortbed C-10, and I now can't put my shocks on due to the u-bolt plate being so close to the lower shock mount.
I took this picture before I tightened everything down, the plate now sits even with the shock mount bolt. Anybody else run in to this problem or have any good solutions? I bought MCGAUGHYS 1850 shocks to put on here.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
Re: MCGAUGHYS axle flip kit
I knew I had seen a thread somewhere http://67-72chevytrucks.com/vboard/s...d.php?t=470952
Still haven't decided how I'm gonna fix this yet though.
I have notched the spring plate before to make room for the nut. It worked fine. On my newest truck i had to weld on new lower shock mounts anyway, so i spaced them far enough away from the plate for clearance.
"I'm Dirk Diggler enough to own and operate a vehicle of this caliber" -veinbar Dropped and LS Swapped SWB 87 Build Thread |
That's what I ended up doing.
Common issue w/flip kits (all brands). Take it apart enough to put the bolt in for shock extension brackets as once they're in the shocks can be serviced w/o issues.
That's the plan later on when these drop shocks need replacing.
