08-21-2014, 09:36 PM | #11 |
Re: 700R4 build thread.
Flip the Drum over.
Replace the 4 Teflon Sealing Rings on the Input/Turbine shaft. Use the One Piece Sealing Rings ONLY, Use Scarf cut or Step cut at your own risk!!!! These are difficult to install without Installer & Resizing tools. There are several DIY methods on the internet/YouTube, Some pointers.... Do not over stretch the Seals, Just enough to go on without damage. Do not Under Size them either! Using hose clamps & what not, Just get them small enough to lightly rock the Stator shaft on them. Install the selective shim & Torrington Bearing on the Input Drum, Slide the Stator Shaft down the Input Shaft to do Final Sizing. Always resize 1 Sealing ring at a time, Start with the Bottom Ring First! The Stator Shaft is bolted to the Pump Body, Use Pump Body/Stator Shaft assembly for Final Sizing.....Just to be clear. Another option is taking the Input Drum to a trans shop for Sealing Ring Install. 1st pic, My install tool. 2nd pic, Found on the internet using a Lip Wizard |
