08-21-2014, 12:07 PM | #1 |
Enjoy your truck
Engine/transmission mounting
I would like your opinions.
In my '63 I have engine mounts, bellhousing mounts and a transmission mount. Are all three necessary? Can I do away with the transmission mount? Is having all three detrimental or is there no impact? Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
08-21-2014, 01:09 PM | #2 |
Re: Engine/transmission mounting
all that is required and works quite well is a 3 point mounting setup. sounds like someone has installed a later manual trans that had a rear trans mount. not required as you have the bellhousing mount. what you have is like someone wearing a belt and suspenders at the same time;you shouldn't have all of those mounting points. eliminate either the rear trans mount or the b/housing mounts. you don't have to remove the crossmember, just take the insulator out
ron |
08-22-2014, 02:03 AM | #3 | |
60-66 Nut
I agree
08-22-2014, 05:43 AM | #4 |
Enjoy your truck
Thanks guys.
Greg.
