Tbi to Carb bbc
If switching from a factory tbi setup to carb on a 87 454 bbc, would I have to use a new cam to work with a mechanical fuel pump? I know I would have to change distributor, and add the mech. pump, is there any other changes/ parts to swap?
Re: Tbi to Carb bbc
Head over to the 454SS website, quite a few of those guys have done the swap
I'm going the other way with a tow rig, I want to run a 4L80E and switching to TBI is the easiest way. |
Re: Tbi to Carb bbc
use the electric pump, that's in the tank right now, but use a regulator to lower the fuel psi use a return style rehulator
![]() Join Date: Nov 2013
Re: Tbi to Carb bbc
X2 on using the electric pump with a regulator. If this is the next generation BBC, it wont even have the provison to mount a mechanical pump.
1967 CHEVELLE MALIBU 427/700R4 1971 CHEYENNE 10 350/350 1983 GMC K3500 454/400/205 1987 R10 TBI 350/700R4 2014 CRUZE 2.0 TURBO DIESEL |
| Bookmarks |
