Old 08-23-2014, 01:37 PM   #51
Russ_the_truck79
Re: Russ the 79 c10
finished up my sound system! i installed two 4" speakers (1.83" deep) up front where the original 4x10 was. The speakers are mounted to a cutting board that is stenciled to the original speaker. (the mounting points are a little bulked up) I made sure to get a 1/4 inch board so that it wouldn't buzz.
I'm very happy with the sound quality of the system especially for all of the speakers being in the middle and for how much I paid for all of it.
could of had an air conditioned honda but,
I'm hard headed and have standards
Russ_the_truck79 is offline   Reply With Quote
Old 09-20-2014, 04:51 PM   #52
Russ_the_truck79
Re: Russ the 79 c10
finally replaced the throwout bearing. still typically screams when i first move. Any thoughts on how to fix this? it's getting pretty annoying... on the sunny side of things Russ doesn't leak oil anymore! help on the screaming sound would really be appriciated
Old 09-21-2014, 07:04 AM   #53
rusty76
rusty76's Avatar
Re: Russ the 79 c10
Originally Posted by Russ_the_truck79 View Post
Square guys are great there are two I see a lot on the road. There's a stepper and an 86 (im 99% sure) 4x4 farm truck rear window guard and all.. Whenever we meet on the road they honk to me and they even honk goin by the house when they see Russ parked out front... I really want to honk back however my truck is hornless so i picked up some semi horns from harbor freight
On another note what do you guys think of this?
I'm thinking build something similar and use a two barrel then later down the line ad all the fuel injection parts as opposed to a buying an suck through carb and bolt on a supercharger off a pontiac bonniville. I found a guy local on craigslist who sells rebuilt ones for 200 bucks
Man that is hot! Wow.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-02-2014, 05:51 AM   #54
D13
D13's Avatar
Re: Russ the 79 c10
The siamesed intake runners don't work well with port fuel without port dividers, tends to run rich then lean particularly on the middle two since their intake strokes are so close. Bunch of learnings on this over at inliners. But mighty cool.
Turbo works better than the blowers. Actually easier to set up, and can do blow thru carb or TBI pretty easy.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-05-2014, 01:36 AM   #55
Russ_the_truck79
Re: Russ the 79 c10
Do you think that lump ports would help to keep things more uniform if i did remove the dividers?
