Old 08-23-2014, 05:51 PM   #1
Lost81c10
Lost81c10's Avatar
stranded.. what is this and can i still drive it?
I am driving and sudenly it starts making like exhaust leak nois. Pulled over and noticed this thing came off. What is it and can i still drive it? Thanks
Lost81c10 is offline   Reply With Quote
Old 08-23-2014, 05:54 PM   #2
MountainGoat1966
Re: stranded.. what is this and can i still drive it?
That is an AIR (Air Injection Reactor) fitting from your smog pump.
In theory it reduces pollution.
I don't see where it will cause any harm, but the noise from exhaust leaking will get annoying.
Wait till the manifold cools off and thread it back in.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 08-23-2014, 06:00 PM   #3
Lost81c10
Lost81c10's Avatar
Thanks for the quick reply. I will tri to screw it back in. Only a pair of pliers on me now.
Old 08-23-2014, 09:09 PM   #4
Keith Seymore
Keith Seymore's Avatar
Which is totally amazing because usually they rust themselves in to the point that they can't be removed, no matter how much persuasion.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-23-2014, 10:43 PM   #5
Lost81c10
Lost81c10's Avatar
Got it put back in there and it worked like a charm. I can't think of how it might have came loose. There is a lot of thread on the nut. It went in pretty easy and no more noise. Got very worried at firt thinking it was a lifter and mad because I just put it back together and first drive after 10 months.
Funny how things work but before i used to think i had to replace my exhaust manifold doughnuts/gaskets because I could hear a leak after I put it back in there and tightened it I can't hear any leak anymore. It was probably loose since I got the truck .
Thanks again for the help and as soon as I saw what is was I could only think of one place to come to to find out what to do, here. My son was impressed how fast it worked to get help and get us on our way.
Old 08-23-2014, 11:11 PM   #6
MountainGoat1966
We have a great community on this site, lots of experience and know-how.
Glad to hear it's fixed and running right again.
Old 08-24-2014, 02:44 AM   #7
jjzepplin
jjzepplin's Avatar
And yes. That can cause serious damage if left loose. If the engine was good and hot and backfired just right you could cool a valve too fast and bend the stem and boom-no cylinder compression and a need for your heads to be redone and countless other problems resulting from said bent valve.
As soon as you can check all of the fittings going to your manifolds. And make sure they are good and tight.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-24-2014, 10:31 AM   #8
Lost81c10
Lost81c10's Avatar
Jjzepplin,
Thanks for your info. I will check them today. If what you mention that could have happened did happen, what would the engine be doing now or will it show it face once the engine has cooled off completely as in the following day? I have not started it today, but yesterday after I put it back in and started it, it seems to run normal, no unusual noises from the engine nor any missing/hasitation.
Old 08-24-2014, 10:38 AM   #9
Lost81c10
Lost81c10's Avatar
K
Keith,
Should I be concerned that it came undone on its own or just just lucky that it hasn't fused it self to manifold. I did find it odd. I have never messed with anything on this area of the engine. Maybe PO caused...
Thanks.
Mando
Old 08-24-2014, 10:56 AM   #10
jjzepplin
jjzepplin's Avatar
Oh you would know right away if damage has occurred. It would have a bad miss all the time.
Old 08-24-2014, 11:10 AM   #11
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Take it back out and add anti seize on the threads. It will save you a headach later down the road. Do to as many ports that are not seized yet.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 08-24-2014, 11:43 AM   #12
Lost81c10
Lost81c10's Avatar
I guess i got lucky again, second time. once with my not frying my electric harness earlier last week by hooking battery backwards and now with not messing up my engine. hope there is no third...
Thanks.
Old 08-24-2014, 11:45 AM   #13
Lost81c10
Lost81c10's Avatar
good point gchemist. i will do that. thanks.
