Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Closed Thread
Old 08-24-2014, 09:50 AM   #1
jjzepplin
jjzepplin's Avatar
Re: 67-72 Chevy Truck fuel gauge diagnostics 101
10-4. Will test the gauge as above.
As for the tank...I am not sure how much is in it so maybe I can test ohm reading after trips as I run the level down. I carry a Jerry can with fuel just for kicks and if I see stranded people.
I am almost a road ranger of sorts. I suspect the sender as it is most likely aftermarket.
I do have a known good unit that I have repaired in my blazer tank that is easily accessible.
Wasn't looking to get into this today but saw this thread and thought what the heck, everything else is working and this has been this way for 10 or so years. May as well do some checking.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline
Old 08-24-2014, 10:04 AM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Sounds good JJ,
keep us posted on what you find out.
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline
Old 08-24-2014, 10:44 AM   #3
jjzepplin
jjzepplin's Avatar
I went and tested the gauge.When I pull the brown wire from the fuse block the gauge reads just past the last "L" in full. Not 3 oclock.
When I ground the fuse block connection it goes to empty. When I turn the key off it slowly creeps back up.
Sender is reading 10 ohms.
I did test a spare gauge and it reads 38 ohms left pole to right pole. (just for reference)
So would the next step be to measure the gauge in the truck?
Think I will try that while waiting for response.
Thank You fellas for all you do.
Old 08-24-2014, 10:58 AM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
thank You fellas for all you do.
"I went and tested the gauge.When I pull the brown wire from the fuse block the gauge reads just past the last "L" in full. Not 3 oclock."
That is strange and would make me think there is something wrong wiith the gauge resistor or the gauge itself.
"Sender is reading 10 ohms."
You are referring to sending unit in the tank, correct? If it is accurate, I would believe you have or should have almost an 1/8 of a tank of fuel.
"I did test a spare gauge and it reads 38 ohms left pole to right pole. (just for reference)"
Did you do this to the gauge in the dash as well? If not, try it but unplug the connector from the cluster so there is no back feed.
Sorry but I have to log off and get to the Airport for El Paso. I will check back on this soon.
We are going to figure this out and get your gauge working properly
Take care,
Tom
Old 12-30-2014, 07:30 PM   #5
Fasteddieb
Best fuel gauge explanation anywhere. Just got a 69 c10 and it had fuel gauge issues. Turn the key on and the needle went straight to full - and past! Bed mounted fuel cell made things a LOT easier. Took out the sender and it read way over the ohm range. problem is, there was an aftermarket fuel gauge in the dash. Did the PO get the 0 to 90 ohm version? I dunno!
Then I had a brain flash. Went to Radio Shack and purchased a 47 ohm resistor. Hooked it up between the sending wire and ground and turned on the key. Needle went right to 1/2 tank!
Ordered a 0 to 90 ohm sender yesterday. I'll have a working fuel gauge by the weekend!
Thanks guys!
Now I need to work on my wiper motor. It's always something!!!
Fasteddieb is offline
Closed Thread
