Old 08-18-2014, 04:49 PM   #1
Lost81c10
Lost81c10's Avatar
I think I out did it all (stupidity wise)
In a rush to try to get my truck started after putting it back together this weekend, I was connecting my battery as the last thing just before starting it. Hooked up the negative and I went to hook up the positive and it sparked, well tried it several more times until suddenly a puff of smoking came from this area of the pic, don’t know what it is. I was scared thinking I might have fried things up.
But here is the stupid part, after 20 minutes of checking and rechecking my grounds I realized I had plugged the negative cable to the positive and was trying to plug the positive to the negative…
After correcting this with no more spark issues, it started.
Do you all think I might have damaged anything especially where the smoke came from and what is it by the way?
Don’t know if this might be related but my one electrical issue is with the passenger turn signal, the light bulb kept going out when I put it back in the lens. Replaced the bulb but it got burnt when I turned the light on. Thanks for everything you can let me know and hopefully I can be put at ease.
Lost81c10 is offline   Reply With Quote
Old 08-18-2014, 07:59 PM   #2
superwade57
Re: I think I out did it all (stupidity wise)
I did this once when I used a cable I had laying around... ie I had two black cables...my helper hooked them up backwards. And poof I let the magic smoke out. As I recall I burned up a fusible link.
superwade57 is offline   Reply With Quote
Old 08-18-2014, 08:05 PM   #3
Sillyoldman
#16876
Sillyoldman's Avatar
I'd be looking for wires with melted insulation grounding out.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 08-18-2014, 09:39 PM   #4
Lost81c10
Lost81c10's Avatar
update.
i messed with it a bit this evening and the light bulb is staying on however when i put the turn signal on the passanger side, the front side marker, rear turn signal and parking light just stay on, they dont want to blink. what gives?
Mando
Old 08-18-2014, 10:18 PM   #5
Just call me Sean
Just call me Sean's Avatar
You have the junction block circled, where most of the fusible links are.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-19-2014, 12:26 AM   #6
Corts60
Just here to tinker
Corts60's Avatar
Originally Posted by Lost81c10 View Post
update.
Mando
I think it is time to have someone come over and help with that electrical stuff.
You obviously have some grounding issues if your lights are doing that. And the first time something sparks, that is the signal something is wrong. Don't try it again and again without having found and corrected the issue. The trick with wiring is to not let the smoke out!
Old 08-19-2014, 12:50 PM   #7
bnoon
The smoke is the angel of your truck, died and gone to heaven. RIP
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 08-19-2014, 01:58 PM   #8
Lost81c10
Lost81c10's Avatar
please explain.....What all do you mean? as in you think its no good? the truck is runnining and everything works with the eexception of the right side blinker not wanting to blink.
No just to clarify, the smoke was a small puff and as soon as a saw the park i took the cable off of the batery terminal, "quickly i'll add"
thanks.
Mando
Old 08-19-2014, 02:44 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
Fusible link for sure.
Frank
Old 08-19-2014, 06:40 PM   #10
asphaltburner
asphaltburner's Avatar
Lack of "blink" with turn signals is usually due to a malfunctioning flasher unit. Try replacing that first. But the smoke probably originated from a wire that had a fusible portion to it and it protected your other wiring by burning out. You may need to rewire in a new fusible wire.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 08-19-2014, 08:55 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
check the light ground on the passenger fender,it burns up if other big grounds get bad.
mine was cut out and replaced,it looked ok but wasn't properly connected
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-19-2014, 09:09 PM   #12
Lost81c10
Lost81c10's Avatar
thanks to all for you valuable inputs.
glad to report back on one finding:
replaced the flasher unit, $11 and my turn signals worked again. boy was i excited about it.
now on the smoke i still have to run down the fusible link issue after the smoke.
i have been searching and reading about fusible links as i know nothing about them. until today i had no idea of them so i am still trying to find out about where they are on my truck and how to test if they are bad.
my positive cable that goes to the battery does not have any other cable coming from it only the red. shoould it have one there?
by the way its an 85.
Mando
Old 08-19-2014, 09:44 PM   #13
asphaltburner
If everything works correctly, forget the fusible wire, it must not have burnt!
The fusible wires are part of the original wiring,...contained within important electrical supply wires in your truck. They commonly have a portion of the wire that is of larger diameter than the rest of the wire (that's the fuse portion) and you would need a wiring diagram of your vehicle to discern where the fusible wires are at. They are not separate wires coming from your battery.
Do check all wires in the region of the smoke carefully to make sure none have severely damaged their insulation. But if it's all working, thank your lucky stars, the truck is good!
Congrats on it only being the flasher unit! It sure sounds like that is the case.
Todd.
Old 08-19-2014, 09:46 PM   #14
Just call me Sean
Positive cable goes to the starter, probably have several fusible links there too but not on the main positive cable. Starter connection feeds the junction block, which has more fusibile links.
Old 08-24-2014, 10:21 AM   #15
Hubscrub
Cruzin
Hubscrub's Avatar
last time i did that on my monte carlo, only fault was i burned the alternator up, but i had it hooked up for several minutes only found out when the power windows worked backwards
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 08-24-2014, 12:58 PM   #16
hatzie
Moderator
hatzie's Avatar
In 1981 there's a fusible link at the junction block you circled and two at the starter. There's also a fuse in the camper wiring at that J block if you have that option. The link is not burnt out or the truck wouldn't have many or any volts in the cab but it probably took a hit.
The 1981 wiring diagrams are in the back of the service manual. You can download a copy from the link in my signature. The engine compartment wiring details with the fusible links are on PDF page 1065 (manual page 8C-58).
The metric wire gauge for the fusible link and the wire it protects are in the diagram. You'll see 3 RED-2G(SXL) and other similar seemingly cryptic notes inline with each wire. Translation (3 RED-2G(SXL)) means 3mm² wire cross sectional area, RED jacket, circuit 2, Subcircuit G, (SXL) "S" cross-link polyethylene wire jacket.
mm² to AWG translation table---->http://www.engineeringtoolbox.com/aw...uge-d_731.html
The OEM fusible links have an injection molded plastic cover over the splice between the fuse wire and the harness wire. Check that the wire insulation on the fusible section is still flexible and not flaking off.
Check the nut on the j-block is snug too.
That being said. I believe the turnsignals are probably a bad ground. Look on the radiator support for a stack of black wires with ring terminals and examine them closely. Detail is on PDF page 1063 (manual page 8C-56).
Check the front side marker and turnsignal bulbs and sockets to be sure all of them are OK too.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
