Egnar
To me she looks like an Egnar, I'll have to admit I do not know what an Egnar looks like, but if I did it would look like this sweet 66.
I finally was able to get her home, and started to clean things up. In the cab was nasty, took the seat and carpet out and pressure washed the inside. I also hit the engine compartment. Plans are to change the oil, then new plugs, rebuild the carb, and start her up and see if there is anything left in her 283 or 327 I don't know which. ![]() There is surprisingly little rust. There is a little in both front lower fenders every thing else looks good. ![]() |
![]() Join Date: May 2007
Re: Egnar
sweet
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Re: Egnar
I started a big remodel on my 71 and have nothing to drive now. So when I found the 66 I had hoped that I'd be back driving.a c10 of some sort.
If the motor runs I,m going to restore the cab inside, new paint get all the dash working and cover the seat in sea foam green and whites. Clean up the dents on the body and clear it. Do a 4-6 drop and tires and wheels. And drive it If the motor which has less that 100 k on it doesn't work I've got a sb 400 and a Saginaw 4 speed that's going In. But I would rather just drive it 71 ![]() |
Re: Egnar
Great find!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Who Me?
Re: Egnar
Gotta have a shop truck!!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: Egnar
Been out working on the truck in between ran storms. I have a nice 40 x 30 shop, you think I would have room in it for one more project but I don't.
Put a battery in the truck and it crank over for the first time, power washed more of the junk out of the cab now ordering some part for the dash. Good day! |
![]() Join Date: Mar 2013
Re: Egnar
Nice truck! I'm willing to bet it has a 283.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Re: Egnar
Today I was working on the motor, changed the oil, new plugs,and I'm rebuilding the carb. I noticed that the motor is painted a blue not orange so I looked at the cereal number and it's odd, it starts with CE. WHAT HAVE I GOT? Maybe a target motor
Re: Egnar
Suffix code CE shows 1957 265v8 162hp manual trans and passenger car application.
Might look for the date code and GM part # too.
Re: Egnar
Thats a nice, solid truck. Looks like it could be the fleetside brother to my 66 stepper Elbert. Elbert and Egnar sound like they are definitely brothers.
#12 | |
Re: Egnar
Found out to day the last owner died about 4 years ago. He had taken the truck in to the shop were I got it to get it running again and never came back. Orphan at a young age. |
Re: Egnar
After inspecting the trucks needs, this what I found
Steering wheel is missing most the horn parts Drivers door missing glass and door handle Steering. Box is bad Wiper motor bad No battery box Driver side exhaust manifold has the threads stripped for bolt that holds the alternator After cleaning out the truck I found everyone of these part the last owner had already found and were just waiting be put on the truck ![]() |
Re: Egnar
I was able to work on the truck today. The truck is sitting out side because there is no room in the garage. With my two mustangs and my 71 swb the 66 has to sit out side.
I installed the new exhaust manifold and the alternator, and now it's rock solid. Made an other discovery, the truck has a brand new radiator. I can not believe my luck, paid $500 for the truck and I got waY more than that in parts. New radiator Steering wheel & horn ring parts Drivers side exhaust manifold Gasket for exhaust Steering box Widow wiper. Motor New drivers side out side door Handel A extra front bumper Drivers side door glass New battery box , I have been rebuilding the carb, and just above ready to start the truck Last edited by Rockit; 08-14-2014 at 01:34 AM. Reason: Remembered one more idem that came with truck |
#15 |
Re: Egnar
Got a love a super deal that's gets better and better.
#16 |
Re: Egnar
A 56 265 will have staggered valve cover bolts. I loved my 265 In my bel air , great motor ! Edomite with some low gears like 4.10s
#17 |
Re: Egnar
The "CE" is a crate engine prefix. Judging by that and the green color, I'd guess a crate 327? Get the whole number and see; should be something along the lines of "T0608DE" (T=Tonawanda plant, 06=June, 08=the 8th, DE=suffix code).
1965 C30 pickup 350/SM420/4.10's (daily driver) thread 1968 Impala 4 door sedan (future driver project) thread Last edited by 66Submarine; 08-15-2014 at 01:25 AM. |
#18 |
Re: Egnar
Not bad for a Utah truck man!
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 |
#19 |
Re: Egnar
Saturday I had about hour to work on the truck. First I put the carb on
![]() Then I cleaned out the gas tank, I got a couple of gallons of nasty brown stuff out and I wanted to see if it would burn so I poured in on the ground and through a match on. Man was I sorry you would of though I was burning an old tire. ![]() I had installed the drivers side exhaust manifold the day before. ![]() Now the alternator is rock solid. I poured a little gas in the carb and the engine fired right up after 10 years and had 50 lbs of oil pressure. I wanted to drive the truck and I would of but I never connected the exhaust yet tomorrow. If the motor is good then I,ll decide my fix or mod |
#20 |
Re: Egnar
Yeah, burning a few gallons of old gasoline on the ground is kind of nasty...
![]() Did you get the numbers off the block and figure out what it is? |
#21 |
Re: Egnar
I went for a drive in the truck. My thoughts, breaks good, steering bad, (needs steering box) good thing one came with the truck. Alternator does not work along with most of the lights.
My plan is to paint the interior, then put the inside back to stock with new paint, rubber, electrical, and a new custom seat cover. ![]() Burn on the door could possible be the last owner lost his smoke and it fell into a pile of McDonald hamburger wrappers |
