Old 08-24-2014, 10:55 AM   #1
blazer2007
pool liner as sound deadner ?
Kinda dumb but friend is replacing their pool liner and thought some of the old liner would work as a sound deadner in the back of my blazer.Is nice thick rubber or what ever it is made of.
blazer2007 is offline   Reply With Quote
Old 08-24-2014, 12:56 PM   #2
midnight rambler
midnight rambler's Avatar
Re: pool liner as sound deadner ?
I would worry about moisture getting under it
midnight rambler is offline   Reply With Quote
Old 08-25-2014, 02:06 AM   #3
andrewmp6
Yeah i just seeing it as a moisture trap.If your looking for cheap sound deadening http://67-72chevytrucks.com/vboard/s...d.php?t=511370
Old 08-25-2014, 09:15 AM   #4
Edahall
For even cheaper and more effectiveness, mix sand into the paint . Mass is what's needed to cut down low frequency noise.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 08-25-2014, 10:15 AM   #5
blazer2007
OK thanks,I,m not skilled in sound deadening techniques but did read that mass rubber was used and thought the pool thing would work
