373 swap to 410 or 456
Hello all,
1996 burb 454, 4l80, 265/75/16.. all stock The truck runs great and tows well. We are towing ~6000 and cover a lot of mountainous states. I would like the lower gear and generally do not tow above 65mph. Question. Has anyone gone to the 456 gears? the L29 torque peaks at ~3200 rpm, what might be the final rpm at 65? was it a positive or negative in the end? I know the 410 will work well but thinking the lower gear will help even more considering speed is not the goal. Thanks in advance, Chris |
![]() Join Date: Aug 2012
Re: 373 swap to 410 or 456
Im looking forward to seeing some responses, I also want to re-gear.....
I know the pieces fit
I had a 99 C2500 that I swapped the 3.73's out for 4.56's and it worked great. Mine was a 5.7 truck. I did have to take it to the dealership to get it programmed for the gears to correct the speedometer.
#7 | |
Blue, I just finished a 2500 mile trip and I am now thinking i might just stay with the 373. What i find is when pulling a hill, (6000# trailer < 7% grade) I downshift to third and the RPMs are 2900 @ ~60mph which is right about the height of the torque curve. I had a few issues with my crank position sensor before and now that that is fixed the truck pulls much better. I do have a donor K3500 now that has 411s in it. not sure if i want to go through the labor of the swap though. |
#8 | |
that should make it a fun ride
I have an 89 5.7 tbi and it ha 373 with 33"bfg. If is way to high a gear. In that truck i might go to 4.88 but at least 456. I have a 4l80 trans to swap in so the steep gear will help it a lot.
#10 | |
I thought about going to the dealership , but I would have to bring my own jar of K/Y.......because its gonna hurt
I am in vegas, not to far from you, I have used Adams Driveshaft for almost 20 years. They are in Henderson, the southeast end of the valley. They are honest and they know what they are doing.
I had a 97 k2500 that had the 454, 4L80 and 4.10s with 265/75s. I towed a RCSB on a tow dolly, with a Dana 60 front, 2 454s, a welder and who knows what else in the back of the 97 with the cruise set at 70, and there is some pretty decent hills on RT81, it never dropped below 70. 350+ miles and used a tank of gas.
2000 Chevy Tahoe Limited 3/5" drop 2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon stock SAS 6" |
Forget swapping gears, swap out the complete rearend. Find a 14-bolt semi-floater with 3.73's. Pop the cover and check gears, swap pinion and axle seals, fill 'er up with your favorite diff juice and you'll be good to go. Complete rearends around here go for $250. They're close to indestructible and even the factory gov-lock works well in the bigger rearend.
#14 | |
My k2500 has 4:10s and I have no complaints. Mine is a 5.7 and you don't notice it's such a dog with those lower gears. Only gets maybe 14 hwy at best though and about 8-9 around town. With a big block i doubt fuel mileage was your worry anyway but you'll lose some doing the swap. Should you want to swap axles (it will be cheaper but quality is obviously unknown) look at the 3/4 ton burbs from the 90s you should be able to find a 14 bolt ff single rear wheel in 4.10 with no problem, most big block/6.5 burbs I see at the wrecking yard have that dif setup.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually 1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr 1991 CR500 (95 Burb wouldn't stop catching fire )
| Bookmarks |
