cab swap ?
ok got a 94 chevy 1500 needs eng transmission and transfer case replaced .so i got a 95 with 350 nv4500 and transfer case ... it was rolled cab is shot .. can i swap cab off 94 onto 95 frame will wiring all hook back up ? or are they diffrent . 94 is 350 4l60e . ??? what say you all who know more then i
64 chevy c10 swb fleet small back window , in progress 454/400 swap , disc front disc rear , and just geting it on the road . 09 ford f350 cc swb 4x4 6.4l , to haul the others home . 2011 chevy hhr not mine but love the milage ..
Re: cab swap ?
no one ...
Re: cab swap ?
If I remember correctly most of the exterior of that truck is the same. The issue would be the interior overhaul that the 1995 got. All new dash, seats, gauge cluster... So on and so fourth. I would imagine that all the connectors would be much different.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
Re: cab swap ?
so all the wiring will have to come from the 94 .and i thought swapping cabs out would be easier then just swapping drive train .
| Bookmarks |
