Closed Thread
Old 08-24-2014, 05:25 PM   #1076
jmorri34
jmorri34's Avatar
Re: What did you do to your truck today? Chapter II
Took it out to the car show Saturday night!!
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline
Old 08-24-2014, 10:46 PM   #1077
Ozzy2013
Ozzy2013's Avatar
Looks good.
Ozzy2013 is offline
Old 08-24-2014, 11:42 PM   #1078
Econman
Econman's Avatar
Ordered a new Hughes rebuild kit for my TH350, including new sprags.. plus a TCI shift improver kit..
Econman is offline
Old 08-25-2014, 07:11 AM   #1079
Elliot949
Elliot949's Avatar
I got my Overload springs Sand Blasted, Primed and Painted over the weekend... I also sand blasted the wheel tubs and got them in Epoxy Primer...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline
Old 08-25-2014, 03:49 PM   #1080
jacob822
jacob822's Avatar
Got my headers, holeshot 2400 converter, lifters, double roller timing chain set, air cleaner, valve stem seals, hardened trans input shaft, and some other odds and ends, getting ready for the install.
jacob822 is offline
Old 08-25-2014, 10:56 PM   #1081
74baggedbug
Removed old homemade fuel tank and installed a boydwelding tank.. Highly recommend, easy installation and fit perfectly .. Also removed old fuel lines and installed steel braided & all AN fittings
74baggedbug is offline
Old 08-26-2014, 11:47 AM   #1082
Mike_The_Grad
Mike_The_Grad's Avatar
Been a while since I've posted on here. But I got it back on the road and put it right to work. I can't say no to free firewood, especially if all I have to do is drive out my drive way and drive onto my next door neighbors property... I was in process of trying to find an affordable material for heat/sound deadener, when I was at the local 99¢ store I found these windshield sun reflectors for $1.27 a piece. Foil on one side foam the other. Bought 5. I stopped by hardware store on way home to pick up roll of aluminum foil tape for ten bux. I spray adhesive the shields back to back so foil would be exposed on both sides, and turned them into panels. I used some good stubble-sided dicky tape in the contours and corners so as not to let them lift. Then foil sealed all sides. I was about four square feet short so picked up a few more to finish the job. Turned out far better than I had predicted, also far cheaper...(I need all the gas money I can get!) I fully insulated the floor pan from firewall to gas tank for about $20! Also I got the low pile carpet for free from a friend. I'm no carpet installer, and I accept that. But it will get me by until I can afford better. It definetly keeps the cab cooler and quieter, even with my "super" 40's! Now I can actually hear my stereo.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline
Old 08-27-2014, 02:47 PM   #1083
texjake
texjake's Avatar
I got my seat back from the upholstery shop yesterday and I set it in the truck temporary just to see how great it's going look. I ordered the seat cover from Seatz out of Anaheim, CA & had a local upholstery shop put the new cover on & installed new foam. I also included a before pic.
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 08-27-2014, 03:16 PM   #1084
Econman
Econman's Avatar
Very nice!
Econman is offline
Old 08-27-2014, 03:42 PM   #1085
texjake
texjake's Avatar
Originally Posted by Econman View Post
Very nice!
Thanks! it's been a huge transformation. And I'm still not done...lol
texjake is offline
Old 08-27-2014, 08:34 PM   #1086
ole dollor
ole dollor's Avatar
looking good , looks better by the day...
ole dollor is offline
Old 08-29-2014, 04:44 PM   #1087
texjake
texjake's Avatar
Thanks Don!
texjake is offline
Old 08-31-2014, 12:00 AM   #1088
allchevy58
allchevy58's Avatar
Bent up some tailpipes today. Got tired of the turndowns after the axle.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline
Old 08-31-2014, 12:32 AM   #1089
texjake
texjake's Avatar
Damn! Nice looking shop you got there!
texjake is offline
Old 08-31-2014, 12:36 AM   #1090
texjake
texjake's Avatar
Nothing major, I wired up my glove box light tonight. It's all in the details right?
texjake is offline
Old 08-31-2014, 07:19 AM   #1091
midniteblues
midniteblues's Avatar
got some epoxy on the cab and finally sprayed some color in the intieror.
in the 3rd pic you can see the darker green between the windsheild and dash pad(thanks sstim)
next is the drip rail sealer and gonna try too start the process of getting the doors and windows jammed out in 503.
oh and because everybody like before and after pic's just mine are backwards
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 08-31-2014, 11:17 AM   #1092
Coley
Coley's Avatar
I did a nice, easy maintenance afternoon where I changed the oil, put on a new lower radiator hose, lubed/greased the front end, rotated the 2 front tires and changed out the power steering fluid and did a little underhood clean and tidy stuff. Nothing too serious.....and, well, it was actually last weekend....LOL
(note: still haven't resolved the increased power steering 'whine' tho'....)
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline
Old 08-31-2014, 04:35 PM   #1093
Sicklajoie
The Niner
Sicklajoie's Avatar
I busted a hood hinge 10 days ago, so Wes from Classic Heartbeat hooked me up with some nice ones.
And I've been driving around w/o power brakes the last month, so I finally replaced the power booster.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline
Old 08-31-2014, 11:33 PM   #1094
texasld
texasld's Avatar
About 32 hours later and it's a different color!!!
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline
Old 09-01-2014, 10:06 PM   #1095
birdistheword
birdistheword's Avatar
Replaced the original 45 year old upper and lower ball joints and put in a set of 2in lowering springs up front.
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1979 Chevy K30 dually currently in pieces
birdistheword is offline
Old 09-01-2014, 11:18 PM   #1096
Econman
Econman's Avatar
Rebuilt my valve body, added a shift kit and started rebuilding the sub-assemblies in my TH350.
Econman is offline
Old 09-01-2014, 11:59 PM   #1097
allchevy58
allchevy58's Avatar
Thanks.
Old 09-02-2014, 01:08 AM   #1098
Tree-50
Finished my seat brackets and got it all in!
Tree-50 is offline
Old 09-02-2014, 03:54 PM   #1099
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Got the wood bolted down and the bed put on.
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline
Old 09-02-2014, 07:08 PM   #1100
jethro5333
started buffing the paint. been a long time since I've done any major buffing. forgot what a pain it can be. especially black!
jethro5333 is offline
Closed Thread
