Old 08-14-2014, 03:59 PM   #1
Venomous
52 Chevy Project.
Hello everyone. I've been perusing these forums for a few months now while I searched for my project truck. Well, I'm pleased to say, I finally found it. I plan to follow similar paths as others have here and of course ask a ton of questions. My first question will soon follow, but first a general picture of my find..
My first question: To those who may have used a Ford 9inch or 8.8, what did you do about the front hubs to have matching lug patterns?
Venomous is offline   Reply With Quote
Old 08-14-2014, 04:51 PM   #2
focusedontheprize
focusedontheprize's Avatar
Re: 52 Chevy Project.
Welcome and congratulations on the purchase.
I am running a Ford 8.8 rear end, however my front hubs were purchased from CPP. They are Chevy bolt pattern, which is fine for me as my front and rear tires are not the same size.
focusedontheprize is offline   Reply With Quote
Old 08-14-2014, 07:11 PM   #3
BlueJeep
BlueJeep's Avatar
Many aftermarket wheels have a 5 on 4.5 and 5 on 4.75 pattern both. Else order a Mustang 2 with 4 on 4.5 bolt pattern.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 08-14-2014, 07:25 PM   #4
nvrdone
if the rear is a drum brake axle just have the axle flanges and drums re drilled to 5 x 4.75
nvrdone is offline   Reply With Quote
Old 08-14-2014, 07:26 PM   #5
Venomous
Thanks for the replies. I work in a salvage yard so I have near infinite options for swaps and changeovers so I was hoping someone could provide insight on some swap spindles that may bolt on with minimal modification. More searching may reveal this answer, I'm in no hurry.
Furthermore I've read most of you guys build threads multiple times and have found a ton if info, not to mention some great looking trucks.
Old 08-15-2014, 08:11 AM   #6
b.sharp
b.sharp's Avatar
well, if you have any 50's chevy cars with disk brakes they will transfer over to the original straight axle. I have a cousin that has disk brakes off something like a '54 chevy car that had disks on his original straight axle. I don't know the exact year of the car but he said it was a direct swap, bearings and all. I hope this helps.
b.sharp is offline   Reply With Quote
Old 08-15-2014, 08:55 AM   #7
Advanced Design
Advanced Design's Avatar
Congratulations on your project and welcome! Looking forward to your project build.
Advanced Design is offline   Reply With Quote
Old 08-15-2014, 10:14 AM   #8
OldChevysRule
OldChevysRule's Avatar
Welcome to the forum. Looks like a decent start. Good luck on your build.
Jason
Trucks don't mind if you have another truck just for "running around town".
My build thread: Double Jeopardy
OldChevysRule is offline   Reply With Quote
Old 08-27-2014, 01:58 PM   #9
Venomous
-EDIT- Thanks everyone for the welcome.
Not much of an update really, just been gathering ideas and parts mostly, making a shopping list.
I do have one question, those of you who are using S10/S15 frames, I know my wheelbase is around 117 inches. Has anyone with a likewise wheelbase used the frame from a 124in wheelbase truck? Any drawbacks or differences than using a 118in wheelbase?
Old 08-27-2014, 10:05 PM   #10
BlueJeep
BlueJeep's Avatar
You just have to use a longer bed. See my build, I used an extended cab s10 frame (124" wheelbase).
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
