Old 08-16-2014, 01:01 PM   #1
FlameOut
Heartthrob Exhaust
I was going to just take my truck and have a custom exhaust, but thought I'd check here first to see if anyone has any opinion on the Heartthrob kit (like this one at LMC Of course LMC is way more expensive than everyone else, so I won't be buying from them. From the Heartthrob page it lists 3 different setup for my 72 4x4. The 8141490 (no mufflers), the 4149SK (stock muffler) and the 4149GP (glass pak mufflers)
The problem is, every time I enter that item at any of the authorized dealers, they all say they don't fit the 72 K10. I did email Heartthrob, to ask why that was happening and got this reply: "you should be good to go, these kits are for the 4wd up through 72 (73 was a model change) and with center dump manifolds. The only “no fit” footnote I would have against yours is if yours has a Rockwell transfer case. Otherwise it should be the correct kit for your vehicle"
So does anyone have any experience with these on their 67-72 K10's?
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 08-18-2014, 09:36 AM   #2
flyingtim01
Re: Heartthrob Exhaust
I have a Heartthrob kit on my '71 K20, side exit behind the wheels, and I couldn't be happier with it. It even fits around the PTO hanging off the SM465. If I remember right, the website is a little tough to decipher with it's footnotes, so good that you got in touch with them direct (I did too) to confirm the application. I seem to remember that I got the 'turbo' muffler, but it looks like the only options now are no muffler, stock muffler and glasspack. Anyway, mine fits great and sounds great, and the kit comes with every piece of mounting hardware you might need.
Get the right part number straight from Heartthrob and then go shopping online to see who's offering free shipping or whatnot, and go with them. I think I ended up buying my kit from JC Whitney.
1971 Chevy K20 350/SM465/NP205
flyingtim01 is offline   Reply With Quote
Old 08-18-2014, 10:23 AM   #3
FlameOut
Good to know. Thanks. I ordered the kit with glass packs from autoanything.com. For $188 shipped was the best price I could find. I plan on changing the mufflers down the roard, but it wasn't much cheaper getting the no muffler kit, so I went this route
1967 Chevelle SS
Old 08-18-2014, 12:03 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I put the same kit on my 71 K20 with the glasspacks, fit perfect, no clearance issues. Going to put the same on my 86 K5 when i swap in the center dumps shortly.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-22-2014, 12:43 PM   #5
lawest
Thinking about buying this system for my K10 project. What is it about the mufflers that you don't like? Are they really loud? If you had to do it again, would you buy the 'no muffler' system? Thanks, Larry
69 K10 SWB Project Dream '69
2011 K2500 Silverado
Beat to fit, Paint to match
Dream '69 Build Thread
lawest is offline   Reply With Quote
Old 08-22-2014, 01:28 PM   #6
FlameOut
I don't actually have my exhaust yet. Apparently no one had it in stock, so it's due to be shipped on next Monday or Tue so I hope to have it by this time next week. I may keep the glass packs, but I didn't want the 'no muffler' option because I wanted the measurements of the glass pack just in case I do want to swap them out. I can't wait for this thing to get here. I need to fire of this engine and really didn't want to do that with just exhaust manifolds on there
I'll get some pictures after I install it. My cab and bed are both off, so it will be good reference for others with smiler trucks, hopefully
1967 Chevelle SS
Old 08-22-2014, 03:13 PM   #7
1tuff71
1tuff71's Avatar
Have any of you used this system with headers ?
1tuff71 is offline   Reply With Quote
Old 08-23-2014, 07:01 PM   #8
lawest
Thanks keep me posted on how it works for you. Especially interested in how you like the glass pacs. I saw an episode of Gears where they visited Heartthrob and talked about the new technology they are putting into them. It sounds like we are at about the same stage in our projects.
Old 08-27-2014, 01:01 AM   #9
seattle gmc
seattle gmc's Avatar
I have this kit on my 70. I ran into a bit of a clearance issue on the passenger side, the exhaust is touching the transfer case. I have a NP205. Are you guys still using your heat riser? Thats the only thing i can think of that might make the exhaust hang down a bit low and rest on the transfer case. That or maybe the section of pipe coming off the manifold was not bent enough? Other than that it seems pretty decent and the glass packs have a nice mello tone to them.
1970 GMC K2500 aka MaTeR
2007 Chevy Silverado 1500HD Classic
seattle gmc is offline   Reply With Quote
Old 08-27-2014, 07:54 AM   #10
lawest
Thanks for the info. So you have a longer drop on the right side because of the heat riser? Can you post some pics?
Old 08-28-2014, 01:33 AM   #11
seattle gmc
Here are some pics, sorry they are not that good. The first is the bottom of the ram horn with the heat riser under it. The second is the clearnce over the transfer case. Its hard to seem from the pic but, the pipe is resting on the front part of the tcase, and i cant push it up any higher. Im not completey sure the heat riser is the problem, but its the first thing that pops up in my head. Hopefully some others will chime in, if they are still running the risers or not. I was also thinking the first section of pipe coming off the manifold might not have been bent enough. for what ever reason i can only post one pic so here is tcase.
Old 08-28-2014, 12:41 PM   #12
FlameOut
I'm still waiting on my exhaust. It was supposed to ship today, but I just got an email saying it will at least be another week!! WTF kind of company is Heartthrob? I'm guessing they have 1 employee that custom makes each exhaust a few weeks after they get the order. If I had to do it over again, I'd look elsewhere, but now that I waited this long, what's another week. I was really hoping I coukd finally start assembling my truck this weekend
1967 Chevelle SS
