Re: Com' On PO - Dangerous Fuel Lines
There is a very big difference in the quality of high pressure rubber hose and the crap they sell on the spools in advance auto zone....
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
Yes, there is! US Coastguard safety standards require the use of a Coast Guard certified rubber hose between the mechanical fuel pump and carburetor on carbuerator equipped engines due to metal fatigue and stress fractures in metal lines made from various Aluminum alloys, Mild Steel and Stainless steel. That hose must meet SAE standard J1527. In that application it is impervious to ozone, alcohol, gasoline, diesel fuel, diesel fuel additives and hydraulic fluid (brake fluid). Properly attached so it does not come in contact with rotating parts of the motor or motor accessory drive, or the hot exhaust manifold this tubing is as safe or safer than metallic tubing.
#3 | |
I'm skeptical because I can understand a marine application needing a flex section between tank line and pump, but why between pump and carb? It makes no intuitive sense to me, anyway. Between the vessel and pump I can see. Or if the pump isn't attached to the engine, then ok.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
