Another new guy
![]() Join Date: Jul 2014
Re: Another new guy
Hey welcome! Love the big hair dryer in the engine bay
Re: Another new guy
Wow...total noob mistake. Came straight to the 60-66 section with an intro without looking at the home page. Admins, feel free to move this to the appropriate section.
60-66 Nut
Re: Another new guy
Welcome to the forum
![]() I see nothing wrong with your post here. Tell us more about your truck and it's engine.
Re: Another new guy
Cool! Hopefully those " run ups" stay on the taxi way. The coffin can single pot master may not be enough to hold back the hairdryer
GOD BLESS AMERICA! |
#6 | |
Re: Another new guy
![]() Eventually that master cylinder is going away along with the rear drums. Everything seems to take 2-3 times longer than normal because I'm only home about 180 days a year. I work out of the country on a 21on/21off rotation. So yeah...slow going build for sure. It also doesn't help that I have "selective OCD" lol. The truck has been in Eugene for a bit getting the manifolds and hot side piping done. As for the engine, it's really nothing special. It made 422hp/412tq on motor on 91 pump gas with a 600cfm shop carb. I didn't really have it on the dyno very long. Enough time to leak check, seat the rings, play with the timing, make some valve adjustments and make a couple power pulls. I probably could have squeezed a bit more out of it, but I didn't really see a reason at that point. It's eventually going to be e85 fed. 8.5:1 355sbc 010 4 bolt block AFR 195 street heads Bullet cam Probe slugs Eagle Rods GM forged crank Vic Jr intake CSU 750 carb (still have to order) twin 44mm Tial wg's BW s475 an old ETS air-air FMIC ![]() ![]() ![]() ![]() It's currently in a typical project state. Lots of temporary installed parts, temporary brackets, mounts, etc. My goal is to get the turbo set up done, get it back on a dyno, see what it makes for power, then continue on from there. Aside from chopping up the core support (which will be reinforced later on), reinforcing the trailing arms and bolting in a Boyd Welding fuel tank, the truck hasn't been touched. LOOOOOONNNG way to go. |
![]() Join Date: Mar 2013
Re: Another new guy
Welcome aboard! Nice truck!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
