08-22-2014, 06:58 PM | #51 |
mini truck racer
Re: 89' s-10 5.3
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
08-23-2014, 01:54 PM | #52 |
Re: 89' s-10 5.3
Good looking truck
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
08-29-2014, 07:29 AM | #53 |
mini truck racer
Re: 89' s-10 5.3
08-29-2014, 09:50 PM | #54 |
mini truck racer
Re: 89' s-10 5.3
I answered a craigslist add about 6 monthes ago for a 55K 6.0 and 4l80e out of a van that was wrecked . The guy had changed his mind and decided not to sell . Well today out of the blue i get a call from an unknown number . I answer and it is the 6.0 guy ,"are you still interested in the 6.0" ? I ask where he is located and he says Baytown . 4 minutes from me . A deal was struck and i now have a low mile 6.0 . My machinist ( built the motor in the yellow truck) ask me if i needed anything . I told him a set of good 243 heads . He has a set with 12000 mile he sold me for $200 . So 6.0 224r and 243 eads . Should make good power .
08-31-2014, 08:14 AM | #55 |
mini truck racer
Re: 89' s-10 5.3
Trans ended up being pretty worn . I looked everything over . Replacing the plastic pistons , all the aluminum bushings . Wide band and new drum , upgraded sun shell . shift kit , servo upgrade . And fresh soft stuff of coarse Should have it back tonight for reinstall . Around the 1K mark , but i am getting to see all the parts go together . I always hate trans work . Leary of people selling stock stuff to you after paying for good parts .
08-31-2014, 09:22 AM | #56 |
Re: 89' s-10 5.3
Like the build. Keep us updated.
08-31-2014, 06:22 PM | #57 | |
Re: 89' s-10 5.3
Good score
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
09-02-2014, 11:29 PM | #58 |
mini truck racer
Re: 89' s-10 5.3
Picked up the 6.0 today . Super clean motor was at the muffler shop on the way home and got offer $1200 on the spot . Hard to pass up , but i kept it . Going to drop off the valve springs tommorow . Also looking at a 92' S-10 Blazer with LS1 and cold A/C .
09-04-2014, 06:41 PM | #59 |
mini truck racer
Re: 89' s-10 5.3
Well got it all in today and running . Converter will go 1800 on the footbrake so 3200 seems correct . It will probably only be 2600-2800 rpm flash in the light under powered truck , but it'll work good good behind the 6.0 later down the road . Trans is solid .
09-07-2014, 09:03 PM | #60 |
mini truck racer
Re: 89' s-10 5.3
Axles have not shown up yet . Truck went from 9.16 to 8.82 with converter , who knows wahat tune . I so bad want to do the 6. carbed , but i am trying to get this fuel injection deal down .
09-08-2014, 10:18 AM | #61 |
Re: 89' s-10 5.3
wtg Hotrod
good luck on the computer tune/FI. who did the trans?
JJ 71 SWB 360 Th400 4.56 |
09-08-2014, 10:03 PM | #62 |
mini truck racer
Re: 89' s-10 5.3
A guy named Rusty here in Baytown . Gong to test n tune friday to practice fotbraking .
09-09-2014, 11:02 AM | #63 |
Re: 89' s-10 5.3
Nice ride.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-17-2014, 09:42 AM | #64 |
mini truck racer
Re: 89' s-10 5.3
Axles showed up , i have the heads in the machine shop right now . Pulling the valves out of the 317's and putting them in the 799's after a surface job and valve springs .
10-14-2014, 10:56 AM | #65 |
mini truck racer
Re: 89' s-10 5.3
I ended up trying to run this at Super chevy and had fuel pump issues . Got it home and think i have it fixed , but it doesnt seem to be making all the power it should . Not sure if its a trans or motor issue . Best pass was a 14.058 @ 96.56 . It follwed up with a 14.060 @ 95.78 . Then the fuel pump issues started . And it slowed over a second . It has solid 52# fuel pressure and it rises to 55#s as i rev it . I dont know any thing about the fuel injection or tuning . I guess it needs to be put on a dyno and worked over with HP tuners . I was also told to move the intake air temp sensor to the front bumper to make it more consistant . Also sometimes the converter will go to 2000 other times only 1800 . This may be more of a brake issue though .
10-14-2014, 12:17 PM | #66 |
Re: 89' s-10 5.3
How is your fuel system setup? Is is a return or a returnless?
10-14-2014, 04:40 PM | #67 |
mini truck racer
Re: 89' s-10 5.3
It has a return line with the truck manifold style regulator . The fuel pump i was told was a 2000 F body/trans am pump . The info im getting is from F body guys at the race track .
Any info i get is a great help as i am about to swap the 5.3 for the 6.0 this winter . Picked up the heads the other day 243 , valve job , seals and valve springs . Also got gasket set and head bolts . About to start the cam swap and bolt it all back together . When i pull the motor i will notch the fram for the A/C compressor . After that i am going to clean up the floor pan . The previous owner cut the trans tunnel for a 6 speed that never got installed . When i do this , plans are to swap the dash with a nice one i have and add aftermarket A/C /heat / defrost . All info will also apply to the 72,000 mile take out set up about to go into my 49' 5 window also . This is another winter project i have .
10-15-2014, 07:00 PM | #68 |
Re: 89' s-10 5.3
224 is a decent street cam. My guess with 243 heads, you will be looking at 380ish to the tire.
IMO the verter will be a little on the tight side, a 4,500 would be a better choice. Remember, with a lock up verter, you can command an early 1-2 shift at part throttle, lock the verter up right after the 1-2 shift and it will keep the heat out of it. This is what I used to do with the 80E and trans temps were 145-160 while driving on the street with a 4,900 rpm verter. The nice thing is you can command it to stay unlocked at WOT until a given speed, or not lock at all.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
10-15-2014, 10:39 PM | #69 | |
mini truck racer
Re: 89' s-10 5.3
10-21-2014, 02:49 PM | #70 |
mini truck racer
Re: 89' s-10 5.3
Ok , HP tunners and air temp sensor help needed badly . Need to make this thing consistant .
10-21-2014, 02:56 PM | #71 |
Re: 89' s-10 5.3
What help are you looking for?
10-21-2014, 05:06 PM | #72 |
Re: 89' s-10 5.3
Is it tuning of the timing table for iat our placement of it that you need help with?
10-21-2014, 11:56 PM | #73 |
mini truck racer
Re: 89' s-10 5.3
Yes , all the help i can get
Yes , i have no ideal what you are even asking .
10-22-2014, 12:53 AM | #74 |
Re: 89' s-10 5.3
Are you using a stock intake or a single plain?
Where is the iat located? There is a section in the timing table that will remove timing if iat is above a certain temp. This can be removed.
10-22-2014, 10:55 AM | #75 |
mini truck racer
Re: 89' s-10 5.3
The motor is as a stock 2002 suburban 5.3 except short tube headers and the small stall converter . I have no idea about the IAT or where it is located . The F body guys either move this sensor to the bumper or front grill area . also some have them fixed with a resister . One guy told me that his settings or tune stopped having variables at something like 80% throttle for consistancy reasons . I am truely new to this and dont want to take it to someone to get a "tune" that wont do what i need it to .
My main goal is a good solid reliable driver , that will be consistant at the track . If not consistant then at least predictable . Would like to put it in drive and let it shift . Also not interested in going faster than 7.50 ( weird request their )
