Old 08-26-2014, 09:11 AM   #576
Rochlow
Re: Project Roxy
Whew.. Glad I saved those coil spring bumper brackets.. Now just have to clean 30-40 years worth of New England under coating off them..
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 08-30-2014, 10:52 AM   #577
Rochlow
Re: Project Roxy
Crappy picture, but I was excited to get the tailgate and bumper on.
Old 08-30-2014, 12:02 PM   #578
ajgriffin
ajgriffin's Avatar
Re: Project Roxy
Nothing crappy about that pic sir! Looks awesome!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 08-30-2014, 12:42 PM   #579
67ctener
67ctener's Avatar
Re: Project Roxy
Looks awesome
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 08-30-2014, 10:13 PM   #580
knomadd
knomadd's Avatar
Re: Project Roxy
Tailgate and bumper look great!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-30-2014, 10:49 PM   #581
Bennett68C10
Bennett68C10's Avatar
Re: Project Roxy
Very nice
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 08-31-2014, 09:40 PM   #582
Rochlow
Re: Project Roxy
Thinking about fuel lines. Does anyone see a problem running braided stainless steel line with -AN fittings from the sending unit (tank still in the cab) to the fuel pump (mechanical pump) . Then from the pump to the carb. There is be two filters in there also, before and after the pump.
Old 09-02-2014, 09:16 AM   #583
knomadd
knomadd's Avatar
Re: Project Roxy
I don't see a problem with it. However, it's just like running rubber hose, but it has an outer armor on it. Meaning: You'll have to change them out as a disposable part once in a while. And it's a lot harder to see the hose fatigue over time because of the braid.
I'm currently running nylon braided fuel line from the tank to the carb (obviously with filters and pump in between). It works fine and looks good, but it's still only temporary.
-Duane
Old 09-02-2014, 11:12 AM   #584
Rochlow
Re: Project Roxy
Thanks for the insight. If the truck was a daily driver hardlines would be a must. However, this truck is a weekend warrior.
That being said, I'm going to need to practice bending metal lines for the brakes anyway, So I should consider bending them for the fuel lines, also.
Old 09-02-2014, 09:10 PM   #585
Last_Paladin
Re: Project Roxy
Nice tail gate
Last_Paladin is offline   Reply With Quote
Old 09-02-2014, 09:34 PM   #586
Rochlow
Re: Project Roxy
Originally Posted by Last_Paladin View Post
Nice tail gate
I know, right.. and I didn't have to sandblast it!
Old 09-02-2014, 09:40 PM   #587
Last_Paladin
Re: Project Roxy
I will send you stainless fuel line.
Old 09-02-2014, 09:57 PM   #588
Rochlow
Re: Project Roxy
Sounds good to me.. Just have to learn how to bend it.
Old 09-03-2014, 09:34 AM   #589
c10Dream'n
c10Dream'n's Avatar
Re: Project Roxy
the before and after pic is awesome...
c10Dream'n is offline   Reply With Quote
Old 09-03-2014, 11:14 AM   #590
superflysteiny
superflysteiny's Avatar
Re: Project Roxy
Looks awesome
superflysteiny is offline   Reply With Quote
Old 09-06-2014, 11:15 PM   #591
Rochlow
Re: Project Roxy
Roxy got a care package from Last Paladin..
Old 09-06-2014, 11:16 PM   #592
Rochlow
Re: Project Roxy
Amazing the things you can do with the right tool.. First attempt.
Old 09-06-2014, 11:45 PM   #593
jlaird
jlaird's Avatar
Re: Project Roxy
Just went through this whole build. Wow, the end result is killer!
jlaird is offline   Reply With Quote
Old 09-06-2014, 11:46 PM   #594
Rochlow
Re: Project Roxy
Thank you
Old 09-07-2014, 09:32 AM   #595
Last_Paladin
Re: Project Roxy
Only problem with that bend and flare is no fitting
Glad it's just practice.
Old 09-07-2014, 09:33 AM   #596
Last_Paladin
Re: Project Roxy
There's no problem with that, but that aluminum line I sent, bent right will be better and easier. I could also send Swagelock compression fittings to fit all of it.
Old 09-07-2014, 09:55 AM   #597
Rochlow
Re: Project Roxy
The piece was already flared. But I figured I try bending a scrap piece just to see how it went
Old 09-09-2014, 11:10 PM   #598
JakeDW
JakeDW's Avatar
Re: Project Roxy
Back where I was three months ago.
Nice work supper clean.
Jake
JakeDW is offline   Reply With Quote
Old 09-09-2014, 11:23 PM   #599
Rochlow
Re: Project Roxy
Jake
Thank you..
Old 10-01-2014, 05:52 PM   #600
Rochlow
Re: Project Roxy
Guy running Dropmembers and disks in the front ( I have CPP 13" rotors in the front). What are you using for brake hose kits from the caliper to the frame? (size, length, etc) CPP has a 7/6" and a 10mm stainless braided kit, but was wondering if I should get the 12" or 14" length.
