Old 08-31-2014, 03:04 PM   #5
91ChevyZ71
Re: 1992 Scottsdale Cluster Swap Help
For a 1991 Chevrolet C/K
Instrument Cluster Connector 34 Pin Connector
O - B is bottom row - Has semi-circle "cut-outs" on edges - I thik for connector - Been a while.
B Wire(s) Colors Circuit Function
17 Brown 437 ECM/PCM
16 Light Green/Black & Light Gray/Black 822 VSS - Low
15 White 121 Gauge - Tachometer
14 Brown 250 Ignition & RWAL
13 Purple/White 821 VSS - High
12 White 696 RWAL
11 Black/White 450 Ground - Gauges - 10 amp
10 Not Used Not Used
9 Not Used Not Used
8 Not Used Not Used
7 Not Used Not Used
6 Not Used Not Used
5 Not Used Not Used
4 Not Used Not Used
3 Light Green & White 11 Headlamp Dimmer Switch & DRL
2 Gray 8 Fuse Block
1 Black 150 Ground
B
O
VSS - Vehicle Speed Sensor
DRL - Daytime Running Lights
A Wire(s) Colors Circuit Function
17 Not Used Not Used
16 Red/White 818 Cruise Control
15 Yellow 237 Safety Belt Warning Lamp / Buzzer
14 Dark Green 35 Gauge - Engine Temp Sender
13 Tan 31 Gauge - Oil Pressure Sender
12 Not Used 507 Not Used
11 Not Used Not Used
10 Light Blue 14 Turn Signals
9 Pink/Black 39 Power - Fuse Block
8 Dark Blue 15 Hazard Flashers
7 Light Orange/Black 419 DRL Module
6 Tan/Black 592 Upshift Indicator Lamp
5 Brown/White 508 ECM/PCM - Check Engine
4 Not Used 69 Not Used
3 Brown 25 Gauge - Ammeter (Generator)
2 Tan/White 33 Parking Brake - RWAL - Brake Pressure
1 Purple 30 Gauge - Fuel
A
RWAL - Rear Wheel Anti-Lock Brakes
Sam
2014 GMC Sierra SLE K1500 Z71 Fire Red Regular Cab
Long Bed - 5.3L (325 Cu In) V8 - 6L80-E 6-Speed Auto
1991 Chevrolet K1500 Z71 Silver Regular Cab - Long Bed
5.7L (350 Cu In) V8 - 4L60 4-Speed Auto
91ChevyZ71 is offline   Reply With Quote
