08-30-2014, 02:24 PM | #1 |
need advice on stock vortec or hump heads (not one vs the other)
Im not asking which is better, but which is a better fit for my particular situation.
I have a stock (heads, cam, pistons) goodwrench 350 with a/c, p/s, dual plane intake, hei, 600 cfm Edelbrock, rebuilt auto 350, original gears, 20 inch wheels. She is just a cruiser but I want more usable power. I have access to a set of hump heads. The 461 variety. With 202 valves, ported, polish in studs, new springs, hardened seats, bowled, that are said to have 10 hours run time. They are my fathers and he has $300 into them. They were purchased as is. So my question is would the motor make better power on stock lift/rebuilt vortec heads with a low lift cam or woulf I get better power out of the hump heads and a higher lift cam. I would like to keep the heads and cam swap close to $600. if i go the vortec route i want to make sure the power will be significantly higher for the added cost of a new intake and covers. I have never swapped heads or a cam but I have always wanted to learn. Its always been a little embarrassing when I say I am a classic truck fuy and have never been deeper than the valve covers! Lol Thanks! |
08-30-2014, 03:50 PM | #2 | |
Re: need advice on stock vortec or hump heads (not one vs the other)
The vortecs do flow a little bit better, and they will already have hardened valve seats, which the double humps won't unless the machine shop installed them. Normal driving below 4000 rpm you probably wouldn't notice a difference.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
08-30-2014, 06:47 PM | #3 |
They are said to have harden seats.
08-30-2014, 07:01 PM | #4 |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
If those double hump heads have had much milled off the surface you should be concerned with piston to valve clearance and compression ratio. It is easy to take a decent running basically stock 87 octane burning engine and make a premium gas burner that produces very little more power.. .
08-30-2014, 08:23 PM | #5 |
You probably won't be able to feel the difference in normal driving.
Your old style intake won't work with the vortec heads.
08-30-2014, 10:34 PM | #6 |
Thanks for the responses!
08-31-2014, 12:02 AM | #7 |
Here is an important point about the 461's that might have a bearing: They don't have the front accessory hole/taps to mount the stock alternator and a/c brackets. If you use these heads you will need to switch to more of an automotive style set-up for supporting these accessories.
Check out under your hood and review where your accessories (Alternator, a/c ) mount against the heads you have access to. All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
08-31-2014, 01:21 PM | #8 | |
Imo stick with gen 1 heads if it is a mld buikd and your truck is an old school or original theme. |
09-01-2014, 11:08 AM | #9 |
....good point Wideside72 about the accessory holes....I've heard about that too.
Here is another tip or approach 'ihatericeburners'. If money and a budget is important (and it should be) then one thing you might try looking into is picking up a set of rebuilt used Gen 1 cast heads. There are a lot of guys out there switching over to the aluminum stuff which has brought a lot of the older cast heads onto the market cheap. If you know what you are looking for you could pick up a really nice set of very useable (possibly rebuilt) heads for minimal money by taking advantage of this. I picked up a fully rebuilt set of '041's myself for under $300, which I'm very happy about. Plus they fit my original engine, manifolds and all accessories without any fuss or 'creeping costs'. All you need is a little time, effort and to watch craigslist or local swap meets. OR if you are really serious, put a 'heads wanted' ad and see what hits in terms of response....ya' never know. My two bits. Coley
09-01-2014, 11:54 AM | #10 |
Thanks alot for the input.
my opinion is: if the two head choices I listed are going to be about the same performance, then I will chose to go with the hump heads. This way I can keep the manifold and covers I have instead of buy the vortec style. And deal with the alternator bracket. Seeing that my a/c setup mounts to the headers anyhow. My next question is where to find the information I need to complete this project. I have to figure out rockers, timing chain, etc. Where should I go from here? thanks! |
