Old 09-01-2014, 02:29 PM   #1
1972BlueC20
1972BlueC20's Avatar
oil level too full?
Stupid question.
I just changed my oil. Used the full size longer wix filter and 5 quarts of oil. The dipstick is showing between 1/2 to 1 quart overfull. What's going on here? On my last oil change, I used the shorter filter and 4.5 quarts and it was dead on full. Any thoughts?
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 09-01-2014, 03:23 PM   #2
tcrist
Re: oil level too full?
I take it that you have started it since you changed the oil? Sounds like a silly question I know, but if you have not started it then the oil is not in the filter yet.
If you have started it, then did the cap in the top of the dipstick slide up for some reason?
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
Old 09-01-2014, 03:49 PM   #3
1972BlueC20
Yeah I started it already. And no the dipstick doesn't look like the handle moved at all.
Old 09-01-2014, 04:37 PM   #4
asolde
asolde's Avatar
I am thinking the dip stick tube is wrong.
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 09-01-2014, 04:51 PM   #5
1972BlueC20
Come to think of it, it seemed like I was about 1 quart short on the oil that drained out when I changed the oil. I was on a slight incline (very, very minimal) but I don't think it was enough to leave 1 quart still in the pan. If it is really 1/2 to 1 quart overfull, what kind of damage could that cause?
Old 09-01-2014, 06:13 PM   #6
sKnNyPpY
sKnNyPpY's Avatar
I would err on the side of caution. Let a little out while cold, don't ask me why not to let it out hot...
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
