Old 09-02-2014, 02:59 PM   #1
86c20
86c20's Avatar
hydraulic oil for engine oil?
ok so thisw was a talk that i have had with a few guys over the years and one claims that he had a guy do it in a forklift he had for a month before he found out and changed it back but said that month it didnt burn any oil and ran better would this work? i mean it will take the heat fine and the pressure fine but what other things would be a problem? this is just for my own info not saying i am going to do it at all but wanted to know what poeple think thats all
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 09-02-2014, 03:40 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: hydraulic oil for engine oil?
Anti wear and detergent additives present in most motor oils will not be in hydraulic oil and certainly not at the same concentrations.
Hydraulic oil will be fairly low single viscosity. 10W?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-02-2014, 05:24 PM   #3
Just call me Sean
Just call me Sean's Avatar
Brake fluid and automatic transmission fluid are types of hydraulic fluid. Is that what you want in your engine?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 09-02-2014, 05:36 PM   #4
mongoose
mongoose's Avatar
technically so is water.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-02-2014, 05:39 PM   #5
86c20
86c20's Avatar
no i am talking real hyro oil.
Old 09-02-2014, 05:51 PM   #6
Axle
Axle's Avatar
What do you think trans fluid, power steering etc oils are? Hydraulic oils with different additive packages and somewhat different viscosities to suit the environment.
Hydraulic oil does not make a good oil choice for internal combustion engine lubrication. It has none of the desirable properties for long motor life. Will it work in a pinch? Yes, it is oil afterall. Did the forklift experience overall reduced life becuase of it? Probably. But you won't know it for a long while given the use and maintenance most forklifts get.
Alex.
Axle is offline   Reply With Quote
Old 09-02-2014, 06:47 PM   #7
Just call me Sean
It is real hydraulic oil.
Old 09-02-2014, 07:57 PM   #8
Corts60
Just here to tinker
Corts60's Avatar
I agree with above. Hydraulic oil is designed for a specific purpose. It is not compatible with combustion by-products and will definitely reduce your engine's life. Not recommended at all.
Old 09-02-2014, 08:25 PM   #9
hatzie
Moderator
hatzie's Avatar
^^^^ That's the other downside to not using a motor oil in the motor... There are several flavors of acid inhibitors in motor oils.
I believe he was referring to the oil based stuff used in hydraulic cylinders to angle snowplows and the three point lift on my tractor.
Brake fluid is generally a glycol based lightweight hydraulic fluid that has more in common with anti-freeze than lube oil. It is a hydraulic fluid but based on his comment not what he was referencing.
There are some really light oils with a heavy detergent package that are specifically designed to de-sludge and dislodge crud. I wouldn't use them either. That crud has to go somewhere and Murphy tells me he will make sure it gums up something far worse than it was gumming before. #10 UTF or Dexron III might do the same thing.
Would #10 UTF Hydraulic oil or Dexron III get you home for a real oil change when you discover you're a 2 quarts low in East Betty BooFoo at midnight? Yes.
Would I run it for more than a short time? NO.
Old 09-02-2014, 09:05 PM   #10
Just call me Sean
Two quarts low isn't emergency enough for me to use the wrong type of oil. Hell my gauge doesn't start bouncing until I'm three and a half low.
Old 09-02-2014, 10:29 PM   #11
kalbert
I guess in a pinch you could, but it'll shave several years off your motor, and if left long enough will just end it. It is not a fix for anything, not a magic potion, and not a good idea. It's better than nothing, but not by much.
Like has been said already, hydraulic oil, like used in a forklift for raising the forks, is specifically formulated to not foam, can't handle the temperature or foreign substances it would contact in an internal combustion engine, and could damage the rubber parts. it's primary purpose is to take up space and secondary is to take up space. It is also a very poor lubricant, especially compared to actual motor oil which is specifically engineered to be very slippery stuff in addition to having detergents and other additives that make it resistant to heat and to carry particles of foreign material safely encapsulated to the filter where they get stuck. It's primary purpose is to lubricate and secondary is to carry garbage to the filter.
You can run ATF in your power steering, and power steering or ATF in your snow plow, but that's it. No other oils can be mixed and matched under the hood or chassis. They are application specific for extremely different applications.
kalbert is offline   Reply With Quote
Old 09-03-2014, 12:02 AM   #12
Rubble
applications.
Hydraulic oil used in a hydrostatic transmission or power shift tranny is required to be a much better lubricant than engine oil.Hydro units are much closer tolerance than a internal combustion engine.Hydraulic oil must be able to absorb water,cool & lubricate parts.When I worked at an IH Ag dealership in the mid 80s,their hydraulic/hydrostatic trans oil was refined to way better specs than their engine oil.Ask anyone that works in heavy equip/Ag related repairs & they will tell you that as well.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 09-04-2014, 06:44 AM   #13
D13
D13's Avatar
Hydraulic oil is not designed to take the high loads and combustion contaminants found in internal combustion engines. It is designed as a pressure fluid with some lubricating and anti-corrosion capability, while engine oil is designed as a lubricant with anti-acid and anti-sludging additives. Two wildly different packages.
You can also run 80w-140 gear lube as engine oil. It works great on hot days with an engine that is totally worn out, it even doesn't leak as bad when your main seal is gone, like on a 400K mile straight six (BTDT). But in a modern engine in good shape on a cold day, it won't flow, and the result is failure of either oil pump drive or rotating assembly.
GM's new engine oil spec is way beyond what TSC hy-trans oil wil ever deliver. Basically all the new stuff needs synthetics because primary oil crudes vary too much in composition and cannot be cracked to the new specs in a cost effective manner. The new trans' and engines require fluids with very specifc properties to operate efficiently.
Oils are engineered for specific purposes. Use the correct stuff.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 09-05-2014, 07:17 AM   #14
Skunksmash
Skunksmash's Avatar
Can you name a couple of the high end ones? I know Redline is one, and AMSoil might be another.. not sure.
I think they could safely be used to get an engine that you know is clean and has been well taken care of, to be really clean. Or if you used them from when the engine was new, so your engine would be spotless on the inside even a couple hundred thousand miles later.
Skunksmash is offline   Reply With Quote
Old 09-05-2014, 10:48 AM   #15
hatzie
Moderator
hatzie's Avatar
Most diesel oils have a pretty high detergent content. It used to be they had a high Zinc and Phosphorous anti-wear add pack as well but the latest generation of diesels with catalytic convertors have forced a re-formulation.
