Weird sound turning truck off
I have a 72 c10 350v8. Sometimes when I turn it of the engine will make a shhhhhshhshh sound. it dosent do it every time, maybe every 7th or 8th turn off. Does anyone have any ideas what this is?
Re: Weird sound turning truck off
Run on maybe?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Sounds like vacuum bleeding off. Could be a leak in the diaphragm for the brakes if you have a booster. Or maybe in the HVAC system
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
A/c compressor will do it too, If you have it.
Hard to tell without hearing the noise. Could be PCV is stuck.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. ![]() |
It not a hose or anything, it sounds like the whole engine turning over. What do you mean by a run on
The only other suggestions I have is a vakve that may be too tight or not seating properly letting compression leak back in to the intake or a loose spark plug, but thats only if your sure it is coming from the engine. You could check both by pulling power from the coil/hei and bumping the engine a little at a time and see if you start to hear it.
![]() Join Date: Aug 2014
Too much timing can sometimes cause a run on. Double check your timing. It could be as simple of a fix of just turning the distributor a little. Good luck.
Having idle speed set too high can cause it. If it keeps on after all our suggestions & it worries you, try cutting it off while still in gear--assuming it is an automatic.
Luck to you, Sam |
